Turning tools on multiple CA coats?
Woodchipper
Cleveland, TN
I just finished gluing several wood blanks. In the past, I noted that there are high and low places with the CA. Can take a lot of sanding and MM to get a good even finish. Pondered using a turning tool for smoothing the surface prior to fine sanding and MM. Will experiment with a skew, round nose scraper, spindle gouge. Anyone tried this or done this?
I am not sure I understand your comment. Are you saying that your blanks naturally have high and low spots or that your blanks are smooth but after the coats of CA that the surface varies? Either way, I think some modifications to your workflow might be required.
CA should go on pretty smooth and flat. An application with a towel or some craft foam should leave possible minor texture to the surface which may need polishing out, but if it's not nearly flat after application, something is being done wrong.
Turning a blank - it isn't really finished until it is smooth and round. If you still have low spots, it's not done. However you turn your blanks - tooling is your choice, they all work including simple files or sandpaper - the blank needs to be turned round, smooth and dimensionally correct before applying finish. If you finish turning and its again not flat and smooth, something is possibly wrong with your technique. Maybe tear out is what you are seeing - ??
Am I missing something or not understanding your question?
Kevin
I've had that same problem, and decided the best use of my time would be to practise the application of CA to reduce the ripples rather than attempt to fix them afterwards. It took a while but the improvement in technique paid dividends.
If what Duncan is asking is the source of your question then I'd agree. I'd look at how you're applying the CA. I had a problem for a while with some pens and figured out the way I was first contacting the pen with the CA and the relative amount of CA were combining to give me an issue.
If you're saying the blank has low spots when you're ready to apply CA then that's a different issue. It could be the wood or it could be a technique. I'd like to think my technique is decent but I will tell you that redwood, even when stabilized, can give me absolute fits because it's density is really wonky.
I have used carbide tools with a light touch to help smooth out the CA finish. As others have said, try and get the CA application as smooth as possible first. My problem was trying to apply too much at a time to build up the finish. Any time saved was wasted trying to sand it back out later, and it never looked as good. Now I just apply one or two drops at a time.
I concur with the advise of smoother application. I used to have uneven CA thickness when I started finishing as well. My solution was to apply more but thinner coats of CA. I tried the closed cell foam and plastic bag application methods but was never able to get the knack of getting a smooth application. My regimen for quite a few years has been to use small pads made from Viva signature cloth paper towels and applying a dozen or more very thin coats. Although I throw far more CA away on the pads than I get on the pen, it has given me the most consistent results with the most consistent CA thickness. About a year or so ago I started using the GluBoost CA finishing products and I am very happy with them. - Dave
It happens, especially using the thicker glues. Spiral ridges can occur if putting the glue on thick. I try not to do that but sometimes I'm less patient and just want to get it done and apply more than I should. I've used a skew to level it all out before sanding. Saves a lot of time and sandpaper.
Wait a minute? You're human like the rest of us? geesh
I can't think of a time I've needed to use tools to level my CA finish before I start polishing. Generally I apply 10 coats of medium CA, level it by wet sanding with 600 grit until there are no more low spots, then wet sand with 1000 and move onto my abrasive waxes (scratch freee, micro magic).
Ha ha, you bet! Most of that time the spots I turn down are from filling cracks or holes in the blank. Sometimes I see them after the first 2 layers of ca so I put a little extra in that area to build it up so I can level it and finish the layers of finish. I'd rather cut them smooth than sand them. Less scratches to worry about.
I make sure the blank is smooth but have some shallow places in the CA glue. Using either Titebond thin or Mercury thin. I did one this morning and backed up a bit to 1000 grit and then to MM. Finished with Hut polish. Came out smooth and shiny.
Sometimes, when I'm laying down a really thick coat of CA glue, I do wind up with ridges or other unwanted texture in the finish. In those circumstances, I flatten it out with a skew presented as a scraper at slow speed with a really light touch. When there are no glossy spots left, I know it's ready for a topcoat, or to polish.
What Eric said above is basically what I do, except I use a custom made scraper, which has the same effect. Light touches and in a matter of a single minute it is smooth.
One extra thing I do is keep my calipers on the table of the lathe and take measurements to match the size of the fittings perfectly.
To join the Thread; Like most, I apply CA to a spinning blank (less than 500 RPM) on the lathe. The centrifugal force (outward pressure) on a wet finish increases the larger the blank, so contrary to what you think, if you put more CA in an area where the blank is just slightly smaller, it will flow outward to the larger diameter. Adding more CA makes the problem worse, and doesn't fix the original problem. Apply many thin coats of CA instead of one massive coat.
Same for me.
