Pen blank?
Wood Knot
Southern Ohio
Does it matter which way the grain runs on a pen blank?
Here's why I ask, I have some really nice tight grained mahogany wood blocks, the only thing is in order for them to be used as pen blanks the grain would run horizontally around the pen.
I agree with all answers above, but as @d_bondi said - sharp tools!! The wood will be at it's weakest if all grain is truly horizontal to the center. Even a little bit of diagonal cut will help - allowing some of the harder, stronger cells of the wood to assist the softer cells along the diagonal joins. If your cut ends up with the wood truly horizontal to center, the wood becomes a stack - soft, then hard, then soft, etc. . Sharp tools will reduce your required cutting pressure which also will reduce the stress to the stack, as well as cleanly cut the wood.
You didn't say if this will be a kit pen with a brass tube - which would be a plus - or a custom pen with no inside structure to assist with the blanks strength, but with some care it will work either way.
Go easy -
Kevin
The grain will run through the pen not around. I know it sounds like semantics but have you ever turned black palm? While the blank might look cool the actual pen is kind of two sided. The grain will look good from opposite 'sides' and plain, blah for the other two sides.
Go easy -
Kevin
Pin kits with brass tubes.
This is what crosscut looks like:
https://www.penturners.org/media/ahp-cigar.3611/
Some woods excel when crosscut:
Heart pine, osage orange, sycamore and bubinga.
If the wood has a very tight set of growth rings, it's a good candidate.
Australia unfortunately as David B. Said. So far I haven't been able to find any that are available and affordable because of shipping costs. - Dave
Yeah I can imagine the shipping would be really high, even the shipping cost here in the US is ridiculous, I've went to order stuff several times and the shipping cost more than the item.
