Drill Worms Update
KMCloonan
Round Lake, Illinois
Well, I know you all have been waiting to see how the Drill Worm Pens turned out. I will tell you, they did not turn out at all like I was expecting them to. After I sat there staring at the turned blanks, I decided to go forward and make the pens, even though the blanks looked nothing like I was hoping.
A couple of details: 1) there were a lot of voids/air bubbles. These could probably be reduced with proper casting technique. 2) I painted the holes in the drilled blanks with white paint, which definitely changed the look of the blanks, but not as much as the actual turning.
Without further delay, here are some pics. I made one cigar pen and one Le Roi (Sierra clone).
1st, the original blank
Then, the pens: 1st is the le Roi
2nd is the Cigar
So, I probably will not make any more of these. Unless we need entries for the ugliest pen contest. 😁
As Thomas Edison once said: "I have not failed. I've just found 10,000 ways it won't work
Great Edison quote!
They are definitely unique looking and I like them.
Even though I don't pour/cast, I can imagine why there might be so many void/bubbles.
What could potentially be really cool is a kitless pen that you internally polish. Then the drill worms would really be the focus!
Great Edison quote!
I still have one long blank left.....
I was thinking it might be interesting to try casting these in a smaller tube and then clear casting over, since the blank surface had a really cool look too. Kind of like a label blank. Might be hard to center the first rod but could probably rig up a mold for it.
