Phillip Head Driver bits??
I am looking for good quality phillip head driver bits like used for sheet rock screws and other screws. It seems over the years they have become so cheap no matter what brand I try. Looking for #2, #3 and #4. I have tried ones they call premium but still strip so easily. Anyone with a proven brand and where did you get them? Thanks
Hi JT,
Although the quality of some products seems to be fluid because of the quality/price trade-off caused by inflation.
I've been happy so far I have been using and am happy with the Makita Impact XPS bits. Mine have a titanium nitride coating.
The Milwaukee Shockwave bits have always been considered a top of the line product. If I didn't already have a lifetime supply of Maktia bits I would likely buy Milwaukee.
A few years ago, Project Farm did a review of several brands of screwdriver bits. Makita and Whia bits were always in the group of best performers in their testing. (Makita bits did pretty good as well and so did Bosch.
I'm curious to hear what others have to say so I will be following your thread!
Dave
I had trouble driving a sheet rock screw in oak. Solved the problem: run the screw in and out to cut threads, then drilled the hole in the second part a bit bigger.
Don't know if you try to screw the screw in all at one time or if in short burst. I have found that by using very short burst of the drill the screws go in easier without stripping the head.
Are the driver heads stripping or are the screw heads stripping?
Are you using the wrong screws? <Video>
Driver heads are stripping. The screws I use are various styles. from standard sheetrock to outdoor stainless and some coated screws. I have tried with standard screw gun, standard drill driver and also impact driver. Seems all have same effect. I have used Bosch, Dewalt, Klien. and bought some Diablo bits about a month ago and all do not hold up. Now none of these are coated with anything so maybe I need to try those.
I'm a big fan of the Star Drive, aka Torx, head as well and always try to find them first. When I first dumped most of my inventory of Phillips head screws I went to square drive, aka Robertson as they were the standard that came with Kreg pocket hole tools. My leap to mostly Star Drive came though when I found Milescraft Star Drive pocket screws a few years ago. Of course I still have quite a few Phillips and Robertson screws on hand, but for anything new I always try to get Star Drive first. Even black drywall screws are available with Torx now. - Dave
A couple things. I do know it is a no no to use sheet rock screws in wood projects but when hanging sheetrock I buy a course thread sheetrock screw because that is made for wood as where the fine threads are for metal studs. I am not over driving when hanging sheetrock so that is the screw for that. But the bits wear out too fast. Now maybe I need to start using more torx head screws for woodworking projects. That could be a problem solver.
