Customer has this pen
J.Louie
Las Cruces,NM
A customer of mine has this pen. It was made in London by TATEOSSIAN. It's a rollerball. The plastic threads in the cap have cracked and broken over time. It has a very sentimental value for her. I think it also has some real value too because the barrel is 92.5 silver and the cap is mother of pearl.
Does anyone have any ideas on how to fix. No kit inserts match diameter and threads. She does not want to send overseas because she's afraid she won't see it again.
+1 on @wade45 's request.
Likely going to need to have a new cap insert machined. You will need to know the specifics of the threads (size, pitch, number of starts) and then find someone with a metal lathe that can duplicate it.
Could you fill the cracked portion with some JB Weld or possibly thick CA and recut the threads?
Just a thought!
or UV-cure epoxy resin.
Step #1 is to determine what the existing threads on the barrel are. With luck it there will be a tap that matches those threads that you can use to re-make the threads in the cap (after building up and re-drilling.) If there's no matching tap available - which is quite likely, I can see from the photo that it's multi-lead - it will take a machinist with a metal lathe to make an insert for the cap and cut the threads. (Or re-cut both cap and barrel threads with something "close" - not going to be a popular choice as it will be obvious when the pen is in use.)
If it were me, I would be hesitant to attempt this without the experience necessary. There are reputable people that specialize in restoration here in the USA. I don't know what the value of the pen is but am often surprised by the $$$$.
Very nice pen that she has.
