Casting Vertically
moke
Cedar Rapids, Iowa
I have been casting for while, in a 6x6 mold and cutting them apart. I like the results for the most part, but am thinking of trying Vertical casting into PVC tubes or even the clear tubes. I like the more finished look to a cylindrical blank.
I pour about 110 degrees...do you guys that pour a little colder to get it to mix or do you push it around with a dowel? I can pour it alternately of course, but how do you guys get the lengthwise color? I use Alumilte Clear Slow, mostly Mica powder, and a Cali Air Pot.
Thank You
I pour vertically using (mostly) clear PVC pipes. I got them from Tennessee Valley Products and my only gripe is that the ID is around .815 inches so they use a bit more resin than .75 inch molds and need a bigger collet. The interiors are much more consistent than PVC I got from Menards also, and this is reflected on the surface of the blank being smoother and more glossy. This doesn't really matter for turning them down though.
Regarding temperatures, I pour between 95-115 degrees depending on the effect I am going for. Pouring cooler will result in more color mixing which looks great in some combinations, but may turn muddy or grey in others. Also, depending on how fast you are pouring and how many blanks you are doing, you are going to get more and more color separation as you go. Pouring hot results in some very cool patterns, but it can be stressful to get the blanks in the pot in time to squash the bubbles. I've discarded a lot of blanks that I pushed to far on temperature which is always a bummer, but I have found this can usually be mitigated by trying to avoid making too many bubbles to begin with.
Regarding stirring inside the molds, I have tried a lot of different things, and found aluminum craft wire to work pretty well. You can attach one end of it to a drill and the other to a vice or pliers, hold it tight and spin it to get it straight, then use wire cutters to disconnect from the drill end. If you let it go slack it can curl back up. I think I have something like 18 or 19 gauge wire. Too thin and it doesn't do anything. Too thick and it leaves ugly trails. It also leaves marks if you bump the walls of the mold.
I pour vertical 8" silicone molds. Depending on what I am going for, I use a combination of pour techniques (swirl, straight in, start/stop) and a thin brass rod. You kind of 'dance' with the pouring cups, sometimes multiple at a time, to develop the main color blends and then 'pull", 'push', or 'swirl' the rod to get some more cool patterns. My rod size is about 1/8 diameter and I bend the ends to get different effects - some just 90 degree angles, some with twists, each giving you different 'mixing' effects as you move the rod within the mold. Temps vary between 95 and 115 on each pour depending on how much separation I want in the final stick. You never know what you are exactly going to get, but you can reasonably copy a pour if you keep good records on temps, volumes of resin in each pouring cup, mica used, mica weight, pour 'style', etc.
Don't go by what the rod looks like on the outside - as that typically reflects what hit the mold as you were pouring, not how it blends inside.
Kevin
I have been using the grey Schedule 80 PVC from Menards - it works great, especially if you remember to use Stoner mold release. (Don't ask me what happens if you forget to use mold release. It's not pretty.). The schedule 80 is a true 3/4" ID, so you get 3/4" rods. The main drawback is the pipe is opaque, so you can't see how full the tube is.
Earlier this week I did a search for Clear Schedule 80 PVC - there are numerous companies out there that sell it, but the several I actually looked at sell it in 10' lengths, which, if you're having it shipped, will require freight delivery, since USPS and UPS can't deliver anything longer than 5' .
I settled on the company in the link below - they cut the 10' length into two 5' pieces and shipped via UPS - shipping was only $10. (Another company quoted me $40 to ship, so $10 seems reasonable.) I ordered the pipe a couple days ago, and it should be here tomorrow.
The clear PVC is also a bit pricey, a 10' length is $34 (so $3.42 per foot), but my rationale is that these won't wear out (assuming I keep them cleaned). At least I will be able to see the resin flowing down the pipe.
Oh that's awesome! I didn't mention earlier but I had looked for Schedule 80 and was turned off by the high shipping. I will definitely order from there when I buy more pipes! Thank you so much for this lead! This probably doesn't matter for personal blanks, but if you are selling it might, but I accidentally scratched up one of my clear pipes on the inside trying to clear some stuck resin bits and it leaves scratches on the blank now, so I retired that piece. I think I didn't put enough mold release in that tube on that pour. Other than that, they seem to just get better with use. My Menard's Schedule 40 PVC has bumps and craters throughout unfortunately.
Seeing the resin go in the pipe is cool but it's not as helpful as you might think. I don't usually have enough working time to examine closely, but it is nice to see how full the tube is if that is relevant to your pour recipe.
I use PVC from Home Depot. I wait until the resin is warm, put in layers, and mix with a thin wire bent into a T at the bottom. Be very careful of over mixing the colors. Once to the bottom with the wire and back up while twisting it is enough. any more it can start to look like mud. As was mentioned what the blank looks like on the outside is very different than the inside.
KM--If if use Stoner spray does the blank pop out easily?
Relatively easily. I use a 1/2" dowel about a foot long - I press the dowel into the tube and push the blank - it doesn't "pop" out, but it does slide out with maybe 10 pounds of pressure (my calibrated arm strength ;)) Once the blank is pushed halfway out, I pull it out the rest of the way. The blank is a bit slippery, so I wipe it off.
One note of caution (from the same "Ask me how I know this" experience.) If you demold the blanks the same day as you remove them from the pressure pot, just remember that the blanks are still soft, and bend easily. Earlier this year I demolded a blank and set it on top of a pile of other blanks. I came back several hours later and the new blank had drooped into an arch, and was almost impossible to straighten. I never got it perfectly straight. If I need to use a blank sooner, I have started annealing the blanks - putting them in a small toaster oven at about 140F for a couple hours (this is per Alumilite's recomendation). After the 2 hours at 140F, I let it cool naturally. (I turn off the oven). After another hour of cooling, the blank seems good to go.
Lastly, I received my Schedule 80 Clear PVC Pipe today. I can't wait to cut it into 12" lengths and use it.
I agree with all the above recommendations and have another vertical option. I use 8.5 x 0.75 silicone molds for most of my pours. The Alimilite slow releases easily and you can easily free the blanks from the mold with an air compressor. I think the lowest price I found them was at Pen Kit Mall.
Elvis...thanks so much.....I always thought you just turned the mold like that off...I did not know they were reusable.
KM- Thank you...that is not a bad price at all, I think....I almost always let the blanks sit all night in the pot under pressure anyway...After I retired I don't go up to the shop at night much at all. When I close the door to go to dinner it stays that way until morning unless it is the 3d printer that is messed up.
Dis Canadian- coat hanger or thinner?
I picked up this Caddy on Etsy and it came with a 3/4" dowel and a nifty piece of HDPE that has a hole with a ledge for holding the tube in place to punch out with a mallet. Useful for stubborn blanks that don't want to push out by hand. The store is on break, but they also sell kits with PVC tubes if you would rather cut into your wallet than PVC. 😂
I personally thought coat hanger was too thick. That's what I tried initially but was getting a lot of wall bumps. Also the thicker the stir stick the more resin it will displace, which can be problematic if you are trying to fill up your tubes to the top and have a shorter pressure pot. I'm planning to get a larger pot and use 12 inch tubes and mark them off at 8.5 inches when I expand the resin shop. Can also do footlong blanks then as well, but my reasons are mostly for being able to cast taller molds for various projects.
I would agree a coat hanger is too thick for mixing. I use a stiff picture hanging wire. My "pressure pot" is a length of galvanized pipe. I think you get better results making smaller batches because you don't have to worry about using a lot of resin before it hardens.
I would use the thinnest wire you can push to the bottom of the tube. It's OK if it rubs the sides on the way down.
I have had an idea to use something like a pipe cleaner but with harder and fewer bristles but I haven't found anything suitable yet. It would also probably be a pain to clean so something might need to be semi-disposable. I think this could result in some cool textures. Just a abstract idea for now.
I have used some very thin brass wire and it didn't seem to do anything. 🤷‍♂️
I bend the Botton end of the wire into a T shape. The T is about the width of the tube. Alternate the colors as I pour them in the tubes, push the wire to the bottom of the tube. on the way up I come up a bit, go back down and twist the wire and come further up and do it again.
I peeked at your posts and you have some gorgeous pours! I don't think I did the T shape for that very thin wire but I did try twisting two of them together with a drill and a T at the bottom and left some cool zipper like patterns. I will have to revisit the T with straight wire. Thanks for the tip!
Thank You guys for helping me and sharing your expertise. I have been making pens for 20 years, but this is a very different skill set, and I knew my friends here would know and help.
Amazing the amount of help we all get here - always good when you can pay it forward! I've been making pens for a long time as well, kits first, then semi custom (using others blanks), and now fully custom as I keep trying my hand at resin casting. I like the idea that everything is 'one of a kind'. The penmaking community just makes it even more rewarding! Hope you create some nice stuff for yourself !!
Kevin
Brief Update - I poured several tubes last night using my clear Schedule 80 PVC pipe - the pour went well. This morning I pressed the new blanks out of their tubes, and something did not seem right. They looked too skinny. I measured them with calipers - sure enough, they are about 0.700" instead of 0.750". While I can probably use these, it is not what I was expecting or paid for. I will consult with the company I purchased the pipe from and provide an update here.
Based on the chart on the link you provided earlier, it looks like the ID should be (on average) 0.742 inches by my calculations. I might expect a little less on the blank, but .4" seems like a lot. What material are you casting and does is it one that shrinks while it cures?
I'm just using Alumilite Clear Slow.
I also did the calculations before I bought and expected possible ID of 0.742". The actual ID ranges from 0.690" to 0.710"
I wrote to the company and am awaiting a response.
I use Schedule 80 PVC, and my rods are .722. Every piece of 3/4" Schedule 80 that I have bought has a .722 inside diameter.
That's what I use too and it usually sinks down a little as it cures but doesn't otherwise shrink. Please let us know what the vendor says. 0.69 inches would be fine for most of my pen designs, but I would probably prefer .722 generally.
I finally have an update for this thread, although it's not much.
I played phone tag with the company and finally connected this morning. Bottom line: what you see is what you get. The rep. said their nominal ID is 0.724" (Vs 0.742" in their specs). I know a little bit about extrusion - you have a cavity and a core, and those set your OD and ID respectively. The rep did not sound at all interested in looking into making a slightly larger ID.
I have made a couple pens with my 0.710" - 0.720" blanks, and they turned out ok. I had to use a smaller size collet chuck which is not a big deal.
It's still decent quality pipe, and I will continue to use it. I just can't sell any blanks made with the pipe as 3/4".
Good to know! I'm pretty happy with the Schedule 40 clear PVC. It does use a little more resin and needs a slightly larger collet than 3/4", but works really well for some of my pour patterns. I just cut up a bunch of my spirals today and was quite happy with the internal texture. However I have heard that you get tighter swirls with a smaller ID, so your Schedule 80 might be good for that! I'm sure as long as you note the actual ID you could still sell them.
Where do you get the plugs for the bottom end of whichever pipe you use? I'll still cast some blocks and slice them up, but have been thinking about casting round rods too.
Thanks!
Thanks!
SpeakEasy Pen has some good items for this - plugs, molds, racks, etc. I met them at the MidAtlantic Turners Expo in Manassas, VA and bought their pot rack and vertical casting molds - might be worth a try. SpeakEasy
I know the thread is a month old but ….
Why don't you just use masking tape over the bottom of the tube? Why over think it. I started out using pvc many years ago and tape worked just fine, but I found that after usage the heat textures the inner walls of the pvc and makes the casts harder to demold. Eventually I was breaking casts to get them out. I guess it comes down to how much you're going to cast.
I cap my pvc with pvc end caps, at Lowes. I line the caps with Saran Wrap. You have to push the Saran liner internally the bottom of the cap or it traps air and bursts.
I use the bright white color 3/4 pvc from Lowe's. Stoner release is a must. The rods are barely large enough to make a jr rollerball, but it works for me drilling on the lathe to get nice and centered. Very little waste.
I never thought about the tight swirls I get being related to the thinner diameter. But it checks out.
I use masking tape. You just have to cover the ends when you spray the mold release in it because the tape won't stick if it gets on the outside of the tube. Also if the end of what you use to mix the colors is sharp you will poke a hole in it.
The silicone caps I have, have a little divot in the center which is kinda nice when parting it out, and they are a little faster and less wasteful than using tape, but I would agree not completely necessary.
