Woodchipper
As the title indicates, what would be the basic setup to start? Or is this in the Library for my own information?
Although I have never used it, I have read many times that because of it's low viscosity, Liquid Diamonds resin can be used successfully without a pressure pot. I'm pretty sure that doing color casts with multiple colors might be more problematic because of the low viscosity, but for clear casts or single color casts it should work. - DaveI'm also curious - if I just wanted to cast pen blanks (nothing larger) from, say, alumilite, is a pressure pot still non-negotiable?
That is a loaded statement. I do not agree with it but I must make sure I put the words "I" because some people here sure get pissed at my "negativity." Seems I have that problem.Seems easier to buy them at this stage of the game. Thanks to all.
Ingoing price is pretty large if you try and make a full permanent setup, but you can get quality results with some shortcuts like using PVC pipe from HD and a slower resin that does not require a pressure pot. Build an inexpensive pipe holder to keep the PVC pipes upright in and order some stoppers from Amazon for the ID of the pipe. A can of mold release is about $10 and its worth it. You can also get sample mica or color packs from some of the providers that will get you off the ground for a cheap start. An IR temp gun from Harbor Freight can be had on sale for under $20 and they do the job. I did it this way to do my first attempt - and it worked - but it also got me hooked into the creative possibilities. My initial outlay was less than $100 and yielded about 15 long rods, which in my brain was a savings.John T., I hit the adding machine keys and came up with $674 outlay right out of the starting gate.
I recall some YouTube videos where blanks were cast with PVC pipe molds and no pressure pot.
Other than epoxy resins I know no other casting resin that does not need pressure pot. The big expense is the pressure pot because you want a good quality and safe one and a compressor. All the rest stuff is materials needed no matter what you use. When you use PVC you are at the mercy of not knowing if there are bubbles until you demold. But to each their own.John T., I hit the adding machine keys and came up with $674 outlay right out of the starting gate.
