How to "control" resin shavings while turning
KMCloonan
Round Lake, Illinois
I am sure this has probably been discussed many times on this forum, but my querying/searches did not yield anything.
I would like to know if anyone has a decent way to collect/control resin shavings/ribbons while turning? I have a 4" dust collection system in my shop, and I hooked up a large dust collection hood to catch stuff as it flies off while turning. This works very well for wood blanks, and even hybrid wood & resin blanks.
When I put a solid resin (in my case mostly Alumilite) blank on the lathe and start turning, everything goes ok while the blank is getting rounded. A lot of small chips fly off and some are sucked into the vacuum hood. A lot also land on my hands and stay there due to static electricity, but I can simply blow off my hands and the little chips fly off.
Where it gets really annoying is when the blank is round - as I'm sure everyone has done, the cutter slices off continuous strips of the resin into long ribbons. Some of these ribbons wind themselves around the blank - I use an old toothbrush to scrub them off. Some ribbons get sucked into the vacuum hood, but often times they form a large, tangled mass in the dust collection system which I end up surgically removing once the vacuum pull is noticeably weaker. I even tried putting a screen in the vacuum hood to catch the ribbons - that lasted about 30 seconds. The screen gets full of resin ribbons and quickly clogs the screen.
Does anyone just let the ribbons fly and clean them up later? Our house must have low humidity lately, because these ribbons stick to everything in sight with static electricity and are a pain to clean up.
I welcome any advice/things you do that work to keep the resin ribbons under control.
Thanks!
Kevin
Kevin; I have a dust hood that gets all the ribbons and sanding dust. I have a "Y" connector in front of the dust collector. Just inside that is a screen to keep large pieces out of the DC. I clean the screen off when the DC doesn't suck any more by pulling the cap off the "Y" and pulling out the ribbons. You may want to check out a cyclone style dust bucket.
Very dry here in Colorado! They do stick to everything. I try to get the dust collector positioned so it gets most of it. I tend to get the accumulation on the tail stock. I take the gauge insert it into the ball of shavings. I make a quick flip up and rotate. Grabs the ball. Flick it into the dust collector. Works for me.
I would like to add that if using something like Jerry shows, you still need to clean the line and or the dust collector depending what type you use. I found that any slight bend the strands collect to the sides of the hose and or at the connector into the dust collector. they can also collect around the impeller so cleaning is still needed after some time. You may or may not notice the sucking power goes down. Just a point of interest because nothing is full safe.
Thanks!
Kevin
yes! I've not seen anyone come up with a foolproof method either and would love one. Well, that's not 100% true I guess. My son was turning a resin blank last week and had his shop assistant (I'll give you one guess who) holding the end of the dust collector/separator near the turning and it sucked up all the ribbons quite nicely. I find that with my particular dust collector/separator (it does both) if I notice something in the line then just a shake of the line resolves it.
I have been eyeing the various systems like the one Seer posted the video showing how well it works. Nothing is going to be 100%. I'm just looking for a lot better than what I've got. If my daughter happens to be in the shop she'll stand there and brush the ribbons away for me while I turn but that doesn't always work well either. I'm just not sure which one is the best one to use.
I have another friend who has the Rockler version of the PSI vacuum attachment. He says it works pretty well and I'm pretty sure that one mounts on the banjo. Rockler actually has a pair of them with different methods to hold them in place now that I look
The PSI one is neat in the fact that it's clear and seems to wrap around the turning work better than rockler's. On the flip side, that would mean the Rockler attachment might work better with a larger selection of items.
Exotic Blanks has a pen makers dust trap also, it looks like it might be the PSI one but I'm not sure.
Kevin, I feel your pain.
I know exactly the issue you are talking about where the massive ball of turning ribbons gets tangled in the inlet of the dust collector.
For me it was at the top of the cyclone where it meets the inlet of the dust collection fan. Mine had a simple "screen", most likely to keep your hands and large pieces from getting into the impeller. When I upgraded the impeller to a larger Rikon, I cut this obstruction out. (see image below). It was what was catching the long ribbons and where the massive tangle would begin.
I "hope" that I don't regret doing this. I haven't done much turning since making this modification, so I don't know how effective it was, but it is one of the steps I have taken.
Good Luck!
David
This is my dust hood. It gets most chips, and every scrap of ribbons and sanding dust. The only two critical dimensions are the distance from bed to lathe centerline, and the height of the banjo to clear the cross brace near the bottom.
Sketchup photo:
https://www.penturners.org/media/pen-hood-and-shield-with-dust-collection.16658/
Real photo:
https://www.penturners.org/media/pen-hood-and-shield-with-dust-collection.16641/
Thanks for the sketches! Something for me to give a go this winter.
At the lathe I use the Penn State Clear Lathe Dust Hood with Magnetic Mounting Clamp. It works well and is a 4" connection.
The one modification I have made is to cut a piece of cardboard that fits inside the hood against the bottom and extends out under the turning area to keep the suction as high as possible around the working area.
Likely not as good as @randyrls solution. I'm going to have to give that a hard look to see if I can modify the design to my needs.
Link please. NVM I scrolled back.
I purchased one of these from Carbatec in Brisbane. It is also available on Amazon. It works really well once you have knocked of the corners off your blank
I used to wear a mask to protect me from the fumes and a head-shield. Now I have a dust extractor and this clear hood
With this device I do not need either.
When working with CA Glue you do need to put a cover over the unit because you will get some glue on the unit.
If you can afford it buy two one for turning and one for CA gluing They cost about $65.00 each in Australia.
Have a lovely day.
I use a skew and pause frequently as I move along the blank. That breaks them up and the shop vac collector has no problem with them. The only time you need a continuous motion is when you are close to final shaping and the finish pass.
Only one suggestion to add to this thread - dryer sheets. The little sheets used to stop static cling in a clothes dryer also helps to cut down the static on stuff when turning resin. Keep a box of sheets nearby and wipe stuff down with them occasionally - works on tools, hoses, etc to help control the static cling of resin turning. And your shop will smell a bit nicer.....lol!
I need to try this! Thanks Kevin!!
I have the PSI pen turners hood that attaches to the banjo. It works pretty good for the ribbons. I have only turned 6 or 8 acrylic/alumilite blanks and I have the problem with some ribbons wrapping around the blank and mandrel, but it is manageable. I didn't think about the ribbons getting stuck in the impeller or a screen of some type on the inlet. Will have to take the hose off and look. I have a Harbor Freight dust collector. It is much better than my shop vacuum at duct collection, and far quieter.
I am going to get some dryer sheets or something. I think there are other ways to deliver the anti-static stuff, we don't use dryer sheets or fabric softener. I am allergic to almost all the scents.
Mike
So it's interesting this conversation started back up. Last Thursday on the Exotic Blanks live session on YouTube they showed this to everyone. It went up for sale on the site Sunday night.
It does not address some of the concerns above but I'm quite interested to give one a shot to see how they work. John said it kept everything from binding up on the head stock.
I'm also VERY interested in the idea of the dryer sheets.
