Spreading CA glue?
Woodchipper
Cleveland, TN
I have fallen into the application of turning the tube while applying the thick CA from the bottle. Last night, I was contemplating the gaps in the glue. I experimented today with wood blanks by applying the CA length ways instead of turning the tube. This should spread the CA all over the tube surface. However, this might be evident by experimenting with an acrylic blank, omitting painting the hole. Your thoughts, ideas and opinions are most welcome.
I dont use 'thick' CA for coating my pens. 3 or 4 coats of thin, no sanding between coats then 3 or 4 coats medium no sanding between coats. I dont normally use accelerator either. I use paper towel that is folded lengthwise in 3/4" to 1" fold, dripping the CA onto the end edge of the paper towel as it is held just underneath the blank as it is turning about 250 rpm (I've tried the plastic bag method but found it made the coating too uneven). I cut off the end that was used to apply the previous coat before applying the next coat. I dont go back and forth more than once over the surface when applying and leave the blank turning while the CA dries. I final sand once the last layer has dried with my micro mesh pads and go through all the pads while the blank is turning. After each pad I stop the lathe and sand lengthwise while rotating the blank by handwheel and move on to the next pad. Rinse and repeat through all pads.
I think applying the CA length wise is going to introduce unevenness.
I have been happy with my method. I have a horizontal dowel that I put the turned tubes on. I put small amount of CA (thin) on the top, and then spread it with my nitrile glove finger, rotating slowly by hand. I like using my finger to smooth out the glue, especially to check that I am not going to have a bubble on the bottom. I never use accelerator. I wait between coats at least 20 or 30 minutes. depending on the material 5 to 20 coats. Then the micromesh to finish. Sometimes a buffer afterwards if I am going for a lot of pop.
I have never glued my glove to a blank, and I have done this thousands of times. YMMV
I believe he is talking about using thick CA to glue the tubes in the blanks. I do not use CA. I always use epoxy.
Oh! Duh, my bad!
I use epoxy also. I've not been quick enough with the CA tube insertion a couple times and I learned my lesson. :cool:
I put epoxy on a sealed one end tube and then insert the epoxied tube, sealed end first, while spinning it. I will insert all the way and then withdraw and reinsert. Never had a failure yet using this method.
Thick CA glue will work for gluing in the tubes, but you would be better off in general using an epoxy. If you made a segmented blank, definitely use epoxy, because you really don't want to ruin that hard work.
As far as application goes, I'll paint the tube with the epoxy (or CA) lengthwise, then twist the tube a bit as it goes into the blank.
I use a small rectangle of craft foam to coat the brass tube with thick CA. I then rotate and slide the blank back and forth over the tube to ensure the inside of the blank is coated. Sometimes i apply a second coat of glue to the tube and repeat, working fast before the first coat sets.
I've been using this stuff for a couple months now and have not had a single problem with it. It stays pretty flexible when it dries, which actually helps it to not break the bond between the tube and blank as easily as a more brittle CA bond. That's been my experience anyway.
Previously, I used regular foaming Gorilla Glue for wood, and epoxy for resin/hybrid blanks. This Gorilla clear works for everything. Also, I push one end of the tube into some dental baseplate wax to keep the glue from getting in the tube. You can use other stuff for that. I saw someone here say they used a tortilla!
Edit: also, I don't notice hardening of the Gorilla clear while still in the container like I did with the original and one part of the epoxy over time
Todd, I considered that. What is the work time, though? Devcon Two Ton is 30 minutes work time. I would consider 15 minutes as the minimum work time. I tend to do a few pens at a time. Five minute epoxy would entail mixing more than one batch. First fishing rod build was with 5 minute epoxy. Started to set as I was sliding the grip down the blank. I did make it...barely.
Edit: Senior moment...saw a YT video where the glue was spread out and the length of the tube rolled in it.
I think I'm doing a pretty standard "spin it and run it in and out a few times before leaving it it in" approach to getting my tubes in my blanks. I use an epoxy with 5 minute working time and 1 hour cure time for about 99% of my pens that are made from a solid blank.
Lately I've been drilling the component pieces of segmented blanks before doing any cutting. Then I can cut off all the segments I need, do a dry fit to make sure it works, and glue it all together and onto the pen tube in one operation. Not only does that mean I'm consolidating down to a single glue-up instead of multiple, it also keeps everything aligned perfectly, and completely sidesteps the problems I've been having trying to drill into solid segmented blanks. For this I use an epoxy with a 30 minute working time and a 24 hour cure time.
