Blank Drilling - The Journey
MikeinOH
Xenia, OH USA
I'm on my 8th pen since purchasing a lathe, and my challenge has been drilling a consistently centered hole. I started using my drill press and a Woodriver Pen Blank Centering Vice. The first five blanks were well centered and straight end-to-end. Then, my holes began starting to skew from end-to-end. The drill bit is perfectly perpendicular to the table and vice. The blanks appear to be aligned in the vice and parallel to the bit. I believe the issue is with the vice, but haven't been able to determine the cause. So, I purchased a two jaw chuck for my lathe. The first two holes are straight and centered, but due to limited travel, I need to stop the lathe halfway through to move the drill chuck tail stock closer to the blank. After that, the drill bit starts to squeal. The hole appears round. I'm sure moving the tail stock results in a little bit of misalignment. Question for the experienced pen turners: is a little bit of squeal normal and unavoidable?
You're on the right track moving the drilling to your lathe. Do yourself a favor and get a set of centering bits. If you're using brad point bits, ditch them. I know lots of starter kits come with brad points. Brad points are not made for end grain and they will wander with the grain. Squealing usually means you're just not cleaning out the swarf often enough.
Thanks Ken. I've been considering getting a centering bit.
I also use the Bostik product as well as simple WD-40 (when drilling resin) to keep things cooler and straight. I also use centering bits on all my initial drilling as suggested by @KenB259. I believe it helps, so worth the time. I also clean the blank thoroughly with DNA or an ultrasound prior to doing any assembly to eliminate any lubricant remnants.
You can minimize the wandering with sharp bits and potentially incrementing the size of your drilling process in a stepped fashion, but it will still occur in some blanks due to the inconsistent hardness of the wood. Oversize your blanks slightly and don't sweat it.
Kevin
I used a machinist's vise on my drill press at first. I used a precision triangle to set the blank parallel with the bit. Later, I splurged and bought the pen jaws for my Supernova2 chuck. The other two weren't available if I recall, https://www.woodcraft.com/search?q=pen+jaws&options[prefix]=last&view=products. Jacobs chuck in the tailstock and proper bit. Low speed and take it slow. Once I had a bit freeze up on the drill press. Too impatient to let it cool.
Could the bit lubricant degrade the adhesion of the brass tube in the blank?
So far I haven't noticed any impact on adhesion, however, sometimes on "special" blanks I will swab the hole out with some denatured alcohol and let it dry thoroughly (like overnight) before gluing the tube in. - Dave
PS For gluing I always scuff the tube with sandpaper, clean it with denatured alcohol, and I use 5-minute epoxy.
Ken, what size centering bit do you use? Looking online it seems they all max out about 5 mm or 3/16 inch diameter
I bought this set at little machine shop. I pretty much though only you the largest one.
Thanks for all the good advice. I batch drilled ten blank segments in my lathe last night, and I learned firsthand how a brad point drill bit can wobble and wander as it starts to enter the blank. I just went to Harbor Freight and picked up a set of centering bits for $7. Those should work for my needs.
I would be remiss if I didn't share a bad experience with Harbor Freight. I was drilling a pen kit that required a 25/64 bit. So, I went to the cheap set of HF brad point bits I bought years ago. Fortunately, I dry fit the tubes before applying epoxy, and I discovered the hole was significantly undersized, 0.013" inch undersized to be exact. Fortunately, I have a Woodcraft store within easy driving distance.
Never used centering bits. I have a Supernova2 chuck and the pen jaws which, to me, eliminate the need for the centering bit.
You'd be surprised. You wouldn't think a drill bit would flex much as they do. When it comes to segmented blanks, a centering bit isn't an option because most designs require a perfectly straight hole.
First thing…. Make sure your blank is true and square. Personally, I do not care about it unless it is a segmented blank or really needs it to be centered.
Moving the tailstock in, should not change the angle of the bit going in. What's probably happening is, if using a Brad tip bit, it's doing its thing and wondering.
Get some cheap centering bits. These will make a huge difference, even if it adds 20 seconds to change out the bit.
Also, I avoid brad tip bits.
I drill at around 650rpms, antler I go slower. Each material is different.
If I need to, I will use a teflon spray lubricant. I use 2 part epoxy for my pens, so I always clean the hole with alcohol. Acetone can work too but it will not play nice with any acrylic or resin blanks.
I like to use jobber drill bits.
When starting the drilling inside the hole, you are starting with friction right off the bat. That's why the they start squeal. Just be patient and cool your bit down a bit.
Don't use water for wood blanks when drilling. You may get a bind. The bit may be cool to touch but the center is still warm and with the friction, you will not only create heat but you will get steam.
A square blank will match up on both ends to drill if you need to flip the blank around.
