Look for these bushings!
PenCasso
Oklahoma
I have an order from a client for a Spider pen, but I've not been able to locate the bushings. Here's the pen kit and the bushings I'm needing. I tried to find the spreadsheet that has all the bushings and which bushings work with other kits and cant seem to find it on here. I downloaded the app and paid the fee and I found the info on the kit, but not what other bushings might work.
Thanks in advanced.
If you absolutely need bushings, check here: Axminster Tools . They have them listed in stock but not sure what shipping would be. You could double check with Exotic Blanks to see if they might have any. Another option is you could use any bushing that will fit the tube (probably the larger of the two lower tube bushings from a Jr. Series kit) that is smaller in hardware diameter that you need and using the calipers, turn to hardware size. You can also get some Delrin round stock and turn down to the sizes you need and make your own bushings. I've made many over the years. Hope something helps.
I called Exotic and left a VM a few days ago and I'm still waiting for a return call. They said they were packing shipping orders, I hope their okay. 🫢
Still going to need some type of bushing as you cannot mount a tubed blank itself between centers.
I'd have to disagree with you on that point. I do it occasionally and as long as you have sharp tools and a light touch they can be turned sans bushings. You'll need to turn the tailstock in as you go. In the end the brass will have a bit of a cone from the centre and the brass slipping but that aids in pressing the parts into the tube. Because the brass does slip some the cone will eventually get a bit of a groove worn into it but it takes a long time before they become unusable.
I believe Exoticblanks has them…. They are listed under the pen info along with replacement ink and drill bits. There's no image for them, just a blue box with a ? In it. Here's a link….
I've seen them there and I can't find the option to add them to the cart. I even added the kit and the bushings and the bushings didn't show up in the cart that way either. Thats why I called them, I might need to call them again and leave another VM.
Big risk to take, especially when the brass flares as you mention. Not highly recommended.
I do this all the time. The ends of the tubes become swedged a bit but not enough that the hardware dont fit right.
Definitely not the right way to do it. I am all for using calipers but flaring the ends of the tube and thus possibly cracking the blank is risky. Even a minor catch can bring an end to the whole thing.
They get real busy at times, and this week following the MPG is more than likely the busiest of those times. You might try calling again.
Edit: well, I spoke too soon, there ya go!
End of MPG, both of us are "sick", and Spectrum has been down, so we can't see the website or orders.
Some weeks have a few challenges, this is one of them!!
We'll be back to normal soon (eternal optimist)
Ed
I guess it takes care and experience. I've never cracked a blank using that technique. Not saying bushings aren't safer just gets you in the ballgame.
To use the app to find other kits with the same (or close) bushings, tap on the "Upper/Cap Bushings" or "Lower/Body Bushings" label.,Thstcwill put those bushing diameters into the search field and perform a search. (In the case of the Spider kit, it searches for matches to "0.531 0.376".
If you don't get a suitable search result, try reducing the search to 2-digit numbers "0.53 0.37" to avoid cases where one kit might have bushings listed as 0.531 and another might be 0.532 or so.
As a matter of course I use a countersink drill bit to make a small chamfer in the ends of the brass tube before turning between centres so that the live and dead centres have a surface to hold on to rather than just touching and spinning on the end of the tube
The tube doesn't splay and the chamfer aids the assembly
It works for me
Mike
Thanks in advanced.
get some delron round stock drill a 7mm hole in it cut a taper and part it off then cut another taper and part it off. you have two centers so you can turn the blank on a pen mandral. you will just have to use a pair of calipers. to check the diameter of the ends while turning. to keep from sanding my bushings I use the delron cones anytime i am sanding and finishing a pen.
RE: bushings; I had measured the OD of all my bushings but, in my ignorance, overlooked the ID of the part that slips over the mandrel. I turned a kit today on the live center and a 60 degree insert in the headstock. Flared the tube a bit but parts fit OK. The tube was for a blank drilled to 3/8 inch. I'm sure I have bushings for most of my kits, now and future.
