Carbon Fiber finished tube-in pen blanks
RonRocheleau
Clermont. FL
I just added a new pen blank. It's a Carbon Fiber tube-in pen blank, smooth pre-finish, for Sierra Twist pen kit. The pen blank is complete and ready for assembly. No turning! The blank is smooth and polished with Yorkshire grit compound and MacGuire polish. Just press together your pen kit with this pen blank and you're done. This pen blank is $12.99 in my Etsy store. Use the link below to save 10% off of everything you purchase in my Etsy store.
I can also provide this blank sized for other types of Sierra pen kits or other pen kits that use the same diameter tube as Sierra Twist.
Other pens and blanks in the pictures are for descriptive purposes only and not included. The beautiful pens pictured are Sierra Twist pen kits from PenkitsMall, as an example of the pens you might make from these blanks.
Just curious as to what resin I'd used, alumalite?……Smokey
These are not label cast in resin. The carbon fiber comes encased in some kind of resin like material and is smoothly coated and sized to fit a Sierra Twist or similar diameter pen tube. I glue in the Sierra tube and cut it to exact size, mount it on the larhe and polish and buff it. Ready to assemble.
