lathe mounted saw
MedWoodWorx
Greece
found this online, has anyone used it before? any thoughts? cheers
I was trying to look this thing up and came across this in my search results
Someone using a hacksaw blade further down in the conversation.
I dont know. This just looks dangerous.
Ok maybe i am overthinking this. I am trying to gather all the tools needed to make bespoke pens on my wood lathe. I thought that this tool wood make nice vertical cuts to ebonite rods. How do you guys true the face before drilling/threading? Just a parting tool is enough?
I cut on bandsaw or on lathe with a thin parting tool and then square the face with a square carbide cutter.
Just my opinion but that saw blade is not going to give you a nice smooth square cut.
I use one of these to true the blank, cut tenons, precise detail turning, and parting when turning on a wood lathe. Very similar to the Sorby tool.
This looks like a knife? Could you please upload a better picture? Maybe i could diy something like this. Cheers
I'm not sure a "better" picture of this is available. It is what it is. It is High 'speed Steel that is 1/16" (1.5mm) thick and 1-1/4" (31.75mm) wide. You plunge cut with the pointed end much like a standard cutoff tool. You will most likely still need to dress the cut off end if you want it to be absolutely square to the centerline axis of the part.
Sorby brand version
Simple tool. I sharpen it every time I use it. I bet you could easily DIY this tool. It cuts like butter through anything for me. Great for cutting tenons if you don't want to invest in tenon cutters. I use this tool for many "kitless" tasks on a wood lathe. It is great for detailed turning. Useful for cutting perfect 1/16 channels for trim rings on pens.
For some reason, I preferred the shape of this one over the Sorby for my needs, but the Sorby is probably better quality.
The think I like about the shape of the tip of the Sorby is that it creates a negative rake for the plunge.
Be careful with deep plunges on these thin 1/16" blades, a little tiny twist in the blade can cause a catch. :oops:
Gabriel Castro (ExoticWoodPen) has a 1/32" parting tool that he made from the steel of an old wood saw. So you can definitely make one for yourself, just use good steel.
My first thought was a cutoff tool also. I've used a hacksaw blade for that purpose, but only with very small turnings, such as a finial piece. I prefer to stick with something safer. The small cutoff tool from the Benjamin's Best mini chisel set works great.
Depending on the material, and the situation, I have used a Japanese saw for parting off. Very thin blade; and held under the material spinning at lower rpm. Still have all my parts and no soiled apparel. YMMV.
Not to the point...my experience with reviews on that site is that (if they are not favorable) they either never appear, or appear only very briefly. Also, IF they do appear, very quickly a number of favorable reviews, that are interestingly similarly worded, appear. This comment based on my experience with that vendor several years ago...the last time business was conducted between us. Again, YMMV.
