Captive Spring
Todd in PA
Port Matilda, PA
After noticing that some models come with a captive spring, I started adding a dab of epoxy into the bottom of the pen to hold the spring from falling out when changing the refill.
Does anyone else glue the spring in?
It is a good idea, but it has one disadvantage:
If you want to convert the pen to a fountain pen, the spring should be removed or it can interfere with a converter, causing the pen to leak.
Just a word of warning!!
Ed
Ed
This is very true! Also, Diamine Writer's Blood ink will make it look like a crime scene. DAMHIK
