Pen Press
Ulm Montana
I'm in the market for a new pen press and I'm looking for some presses other turners might use. Mine is old and worn out and giving me a lot of trouble. So, if you have a favorite press that you really like I'd like to know about it. Thanks in advance for any ideas and help.
This is the one I use. A bit pricey but I like the ability to disassemble pens. As far as just pressing the pens together it's just as good as any others I've tried. I used to disassemble pens with a punch and a hammer. The problem with that is I messed up more of the plastic threads in rollerball caps than I saved. The smooth even pressure really helped with that. I haven't lost a threaded insert since using it. I'm pretty particular about lining up the patterns on the cap and pen body so I've disassembled more than I care to admit. It also came with a rubber tube so it doesn't mar the blank.
You could turn your lathe into a press, a drill press can work or of you have one, an arbor press is a possibility. Hope these options help you on your journey.
Not a fan of a lathe as a pen press. If you have to then make sure you are pressing on centers. There are examples of home made presses in library. Others use clamps. But a dedicated pen press is designed for the pressure needed
A refinement of the one shown in your post. Yours is the same that I have used for a few years. However, were I to do it again, this is the one! Simpler to use, particularly is the changeover from assembly to disassembly and back again.
Agree with John on not using the lathe. Too easy to be off just a hair and split the blank.
Definitely. I cracked two blanks with a pen press by putting waaay too much moxie on the blank.
I started with the press parts for the lathe but found it too cumbersome. Actually, I got the pen press for free but I did send the person a check to cover S&H and time.
I mentioned to the OP because they were seeking alternatives.
workbench vise and oak jaw covers
This is another great option that I forgot to add to my list.
Another vote for the PSI assembly/disassembly press with some hdpe collars. When I get around to getting a thicker bit of hdpe I plan on putting a sleeve on the aluminum side of the press instead of trying to juggle that flat piece on the end there. (another brilliant idea stolen from here)
I've been using this home built one since the mid 2000s. Has worked great for me. Matthew Services in the name on the plans. If you need, I can send you or anyone a .doc file of it.
I have the Milescraft press, it's worked well for me
I just bought one of those this past week from Amazon because of free shipping. I always liked that design after watching Chad from Turners use them and the ease of adjust lengths. It is super well built and has some weight to it. The drawer under it is actually a great idea. A better mousetrap as they say. I have an older PSI that I have used for years and still works but is slipping more these days. All the talk about pen presses just push me over the edge. These days it does not take much. Just some late night no sleep shopping.:)
I have the PSI one. I can already see the improvements in this one that would probably solve all my complaints with the PSI. starting with the darned double-wingnut locking nuts for the clamp in the middle!! Hateful design! :P This single-knob approach is so much better, and it looks like it has a locking lever to hold it in place underneath as well.
Glad to see the info on this one. I bought a fellow's perturning equipment back in Dec 2023 shortly after having right knee replacement. Knew I had picked up an extra pen press with this purchase. Sold my home right after making this purchase so never got a chance to use any of the equipment. Finally getting totes opened up in my tiny shop & there sit this same pen press. Looking forward to trying it out.
Does anyone know if this is available in the states? I found it in the UK and Australia. I might buy from AU, price is pretty good (still a lot more expensive than the press I have). Just wondering if its sold directly stateside or not.
