I acquired carbide bit turning tools from China suppliers about 8 months ago. These tools are made by "TASP". The handles are around $5USD, the tools are sold separately ($5-20USD). They come with 1 carbide. TASP sells the carbides in 10packs for $25USD.
The only issue I have encountered: the tool will unscrew from the handle after some use. I do not anticipate a reason to ever unscrew the handle so I applied green locktite to lock the handles on the tool.
Difficult to fully explain but I will try in the attached photos. The bar steel/carbide holder is held into the handles with 2 alan worm screws; I never had a problem with those worm screws. The problem was in the holder.
The first photos attached are from the online store listing so you can search aliexpress/temu/banggood for the product. The next photos are my attempt to demonstrate the problem I encountered with all of them. Again the problem is easily solved with loctite. The back of the handles also come unscrewed under heavy use: loctite can be used to solve that as well.
TASP also makes standard HSS tools; I will review another time.
