Experimenting, again
See more from Hippie3180
Hippie3180
Texas
I've been experimenting with casting floral blanks and internal polishing. Internal polishing is challenging to say the least. I've got it maybe 3/4 of the way figured out, and it's just something I'll have to keep doing to get better at.
  • IMG_0825.mov
    30.9 MB
leehljp
Member Liaison
Tunica, Mississippi,
Are you familiar with the flame polishing method? It takes some practice but it works well.
The first link has a link down from the top that deals with flame polishing acrylic du k calls and I believe it is adaptable to pens.
Hippie3180
Texas
I
I saw this video, will it work on Alumilite do you think? This guy was using Acrylic I believe.
Hippie3180
Texas
I
Not 100% sure, I will let others comment on this. If you have an old Alumilte blank, try it and see. I think it will.
I tried with a small butane torch and it didn't work. I'm not sure if it's a temperature difference in torches perhaps or that Alumilite is polyurethane.
Does anyone have any input about this?
Dannv
Sparks
FWIW< I made myself a small mangrel that will hold a small piece of zona paper. I polish the inside of anything i make that isn't totally opaque.
Dannv
Sparks
Is this mandrel something like a dowel with a slit in the end, where you put a piece of Zona paper in the slit and either spin the mandrel in the headstock or a drill while moving the piece over it?
Yes. I chuck it in my collet chuck on the lathe. Mostly I just go through the zona grits, but I have also used a piece of shop towel with plastic polish on it to finish it off.
