Caribbean Rosewood Burl & Turquoise
See more from ZanderPommo
ZanderPommo
Tenino, Washington
On a black titanium Zen rollerball. 🍻
Beautiful pen/blank. I have not seen Rosewood Burls with inclusions very often, but your turquoise inlay is very appealing. I love it! Thanks for sharing. 👏 👏
Thanks! I bought a huge burl cap without realizing the full extent of the inclusions until I found them in 90% of the blanks I ended up with, which I believe is why they didn't sell well. First burl cap I've lost money on, but lesson learned. It's incredibly dense though so it makes for good easy practice for doing inlays in voids. And now I have a lifetime supply to try different inlay techniques 😂
I really like the way the turquoise looks in the rosewood and the black titanium is a perfect pairing. Nicely done Alex!!
How did you do the turquoise?
Burls are like chocolates! And for what you did, I might suggest you may have a great solution and an attractive visual for the remainder.
I turn down the blank till it's maybe 1.5-2mm proud of finished size, take it off the lathe and then use a tiny scoop to fill the voids, tapping repeatedly to ensure they get filled, then drop in a couple drops of thin CA which wicks through very quickly, and hardens almost immediately.
Once all filled I hit it with a spray of accelerator just in case, then turn juuuuust proud of finished size and do it again to any spots that are still unfilled.
After that there may be some voids too small to fill, so I put some medium CA on 220 grit sandpaper and create a sawdust/CA slurry at low speed. Then hit it again with accelerator, sand to finished size to 600 grit and apply my CA finish.
Cool, thanks for the detailed explanation.
I like that last step, the medium CA on 220 grit, I'll have to give that a try sometime.
brilliant process, thanks for sharing
