MPVic
Has anyone experienced slow drying of the Starbond odorless thin??? I am tying it as a finish and the fact that it's odorless.
Actually my "shop" is indoors so temp is no problem. But I really like your suggestion about the hair dryer - thanks.Mark, is your shop heated? Do you keep it a temperature lower than 70°F? When I lived overseas, where I started pen turning, I learned that around 18°C and below caused the CA to take more time to cure/dry. Since I learned that, I have kept a hair dryer in my shop ever since. While I have a heat gun, they get too hot too quickly, but with a hair dryer it is easier to control the heat and does help speed up the process. Drying/curing does better above 70°F /20°C.
DuncanIt might not apply to all varieties of CA, but I know that some of them act faster when the humidity is higher. Where I live (Boston area) and Canada at this time of the year typically have a very low RelH so that might be impacting the set/cure speed.
yeah, you don't need to ask me eitherOur normal CA will stop wounds but it hurts like***** when you apply them , steri strips are so much nicer DAMHIKT
