OK, I am seeking some advice from people who have used both
Do you find a difference between the two when you use them? I know both need a sanding sealer to start but am unsure if one is better than the other.
I use a CA (GluBoost) on my pens and sand them all to 600 before the CA goes on. Would I still need to do a sanding sealer or does the CA serve as the sealer and then I can just go to town?
My current process is to wet sand with micro mesh up to 12,000. Does either product put a similar "grit" level of finish sanding/buffing?
I'd like to use them without CA on larger turnings like bowls or pepper mills too.
Thanks for your opinions
