Premium Designer in Cocobolo - Center Band Modificaiton
See more from egnald
egnald
Columbus, Nebraska, USA
Greetings all,
Today I finished up another PSI Premium Designer NT in Cocobolo with a much nicer color compared to the one I posted a day or so ago. (The pictures don't do it justice). I did a modification to eliminate the center band on this one. It is finished with my standard CA regimen instead of GluBoost this time.
Regards,
Dave
Lovely pen, Dave.
I really like the continuity of the wood over breaking it up with a metal center band.
Hi all, since posting, I took it apart and put a small radius on the upper blank to soften the transition between the upper blank and the lower and then re-touched up the CA finish on that end. I think it looks better without the harsh step you can see in the initial photos above. - Dave
Before and After radiusing the Transition.
Finished pen After Radiusing the Transition
View attachment 358573 View attachment 358574
Yes, David, that improves the look.
Excellent bit of work there, Dave. I really like this version of the Euro NT. Less bling and more Cocobolo is a recipe for success.
