Second closed end pen
See more from Hippie3180
Hippie3180
Texas
I made another closed end, it's fun, something new leading me closer to the kit less goals I have. As you can see it's another black walnut, we have a lot so it gets used often for experimental type things. I had to use two pieces again to have the length I needed so I could part off the body. This closed end is flat on the end where as the previous one was a bit rounded.
Looks like you got the hang of these pretty quickly. What are you using for a mandrel? By the way, I think every experiment I've done has been with walnut also.
So, because this was a kit, we drilled one end out and inserted a tube. Then we put the Jacobs chuck on the headstock and put the tbc in the Jacobs chuck, then the bushing. We used the 60 degree on the tailstock and turned the body. For the cap we put it on an actual mandrel and brought the mandrel saver up to the cap bushings. To sand the body we put a punch (we have a set) just smaller than the tube into the Jacobs chuck, put painters tape on the punch to make a crude jamb chuck…this kept the body blank from slipping so we could sand and finish. Basically, it's a convoluted set up, but it works. Most folks have a Jacobs chuck and a tbc, so if that's all you have you can turn closed end.
First pic is set up for cap. Second is set up using punch in Jacobs chuck to sand and finish body.
It sounds like you are working on my budget, LOL. The tape makes sense, though. A pin chuck might give you more accuracy going forward, but this seems to work well for you at the moment. I've been meaning to play around with this a bit, too. Lately, I haven't even had time to make anything in the shop.
Very cool and attractive pen.
The the couple of closed end pens that I have made have sent me down the rabbit hole - I bought the PSI Big Grabber mandrel just a week ago. I have a couple of closed end blanks drilled, painted and drying. I painted the inside of the blanks (plastic blanks) and it seems like it is is taking forever for the paint to dry deep in the hole.
I'm anxious to see what is next.
Dave
Clever use of the tools and equipment at hand.
