Center finder
gimpy
Danville, Pa
Good day folks,
It's been several years ago, some one on
this site had made plastic center finders
does any one have have knowledge of
these or where I may find them
Thank you in advance
I don't know if this is what you are referring to, but I think that one of the forms moderators or maybe former moderator, alphageek, Dean Charlier, from Wisconsin used to make them with a 3-D printer. I recall someone talking about a setup he did at one of the pen gatherings. - Dave
I forgot where I got them from and they are still packed up, but I know I have a small one for square pen blanks and a large one for circular center. I found the small one I have on ebay.
Exotic Blanks has made them in the past.
NOT RECOMMENDED as a Center Finder:
https://www.rockler.com/caliper-gauge-center-finder
This Rockler tool is a plastic center finder and caliper setting tool. I like it and use it as a caliper setter. I do not like the Rockler tool as a center finder. The problem is that the center section is too thick, which makes it hard to get a pen or pencil in the slot to draw the centering line.
Recommended, but not plastic:
I use the center finder that comes with a Starrett 12 inch combination square set. Search for "Starrett combination square" and look for ones that include the V-shape center finder. Starrett is a very expensive name brand, and you can find much less expensive versions of their combination square and center finder.
-> This is the one case where I urge you to spend the money for a true Starrett brand combination square and center finder. It costs more than all the others, but is so worth the expense, in my opinion. Consider it a "lifetime investment."
When you say center finder though that can mean a few different type tools. The tried and true method of square blocks is opposite corners draw a line and where they intersect is center. Finding center of any sized tube lengthwise is easy by laying tube on a flat surface and place a flat even piece of material next to it and draw a straight line down the length.
Bingo, thats what im looking for thank you
yes, square blocks in opposite corners and draw a line
