I had a go at abandoning my usual approach of only working on a single pen at a time and tried making five pens at once. To be honest it was a bit too much.
I have made multiple pens at a time before but on those occasions I'd get the pens to a certain initial state, basically barrel and cap drilled and threaded, and then take one of them and work on it to completion and then go back to the next.
However this time I did it as if it were a production line by repeating each individual step five times. Just to see how it went.
There are obvious benefits and economies to be had in doing that. For example once the first barrel is turned down to final dimension then the lathe is dialled in for the next 4 so you don't have to measure as often. But I did find the repetitive nature of it tedious and just wanted to get something "finished". This is why I always turn down offers of collaborations. It usually involves making multiple versions of the same thing and doing the same thing over and over just doesn't appeal. (Oh and the finishing/buffing nearly did for me).
Anyway here they are. All 13mm triple lead with 100% recycled sterling silver details and a chrome pocket clip. Jowo nibs fed by cartridge/converter.
Cheers
Ash
Cheers
Ash
