I can make that statement. And did.
As to exceptions, there are rules and exceptions to rules. So it can be said.
John, to quote you from another thread "that is nit picking." You do that for me, you do that for Ken, and you do a few others that you don't seem to like. Are you jealous or something? I can't figure a single reason for anyone as top notched skilled as you are - to be making nitpickiing comments like you do. Anyone as highly skilled as you don't need to nitpick.
"TBC" describes the moving from the "Mandrel" to the centers directly (or with bushings) - without the mandrel. You know this and you accepted it for ages. Now, it seems like suddenly you want to nit pick that term. You are too skilled of a guy for that. There are many words that change over the years. That is a given because language/words change often and then give different connotations to incoming generations. That is also WHY I called it Mandreless back then, but several others here started calling it TBC. Since I am not the nitpicker, I let it go for 14 years and it still does not bother me to the point I will complain about using the term TBC.
IF you want to pull up the articles in the library, just remember that I told you "Mandreless" was used before the term "TBC" got started. Thank you and you are welcome. BTW, the article you listed is relatively new although that method did exist years ago. My references go back to 2008. IF you want, I can probably dig the very first post asking for that method (mandreless) which became TBC. If you want to do it, look at Johnny CNC and Rifleman. Those were the two that told me about a method that a couple of other guys used to turn without the mandrel. FYI.
