Cartaphilus
I'm a relative newbie to acrylic pen making and I do my finishing with a standard 9 pad set of pads.  How long can I expect to use a set and still get good results before I should replace them?  Thanks...
			Days to years depending upon how much love and attention you give them . If using them dry , won`t be too long . Use clean water with each pad , rinse off , store separately from other pads , in a pen kit bag , is what I do .I'm a relative newbie to acrylic pen making and I do my finishing with a standard 9 pad set of pads. How long can I expect to use a set and still get good results before I should replace them? Thanks...
My process exactly!Also, buy the packs that are the size of a 1/4 sheet of sandpaper and cut them into 4 equal pieces. Gives you 4 sets of micro mesh pads for about 20% more than the cost of a single set.
Thanks, Wayne. Good to know. I've been spraying mine with water from a spray bottle when using, but I haven't been rinsing them afterwards. Gotta add that to the process.Days to years depending upon how much love and attention you give them . If using them dry , won`t be too long . Use clean water with each pad , rinse off , store separately from other pads , in a pen kit bag , is what I do .
Thanks to everyone who replied. Nice advice.I'm a relative newbie to acrylic pen making and I do my finishing with a standard 9 pad set of pads. How long can I expect to use a set and still get good results before I should replace them? Thanks...
Don`t know if it makes a difference or not , but I also dry them thoroughly after each session . However , I use compressed air to do that , which occasionally assists in de-laminating the fabric from the foam .Thanks, Wayne. Good to know. I've been spraying mine with water from a spray bottle when using, but I haven't been rinsing them afterwards. Gotta add that to the process.
This ^^^^ is a perfect match for what I do.Days to years depending upon how much love and attention you give them . If using them dry , won`t be too long . Use clean water with each pad , rinse off , store separately from other pads , in a pen kit bag , is what I do .
Nope, definitely not the only one. That's part of why I replaced the first set. Darn those tight spots.Also stay in motion. Press a little to hard to get into a tight spot or folding to form a smaller edge (which some recommend) will burn a spot through the grit surface pretty quick. Unless I am the only to have ever done that.
Thanks for that Dave.I do pretty much the same as Mike aka MrDucks2 does. A couple of years ago I bought a bunch of them when they were on sale for $11 and cut them into 4 individual pads each 2 x 1-1/2 inches. I only use them for wet sanding and since I started adding a drop of rinse-aid, aka Cascade they have been lasting much longer than I anticipated, like one set lasts me a year before I swap them out. I use rinse aid, but I used to simply use a couple of drops of dishwashing liquid. I think the soap (surfactant) helps the particulate material wash away and in my opinion, also extends the life of the pads.
Dave
I'm curious to know about this, too, for the same reason.Does anyone know if you can get individual grits of the MM anywhere? I recently did a batch of 110 pens, and started with a brand new set of MM for them. By the last pen, the lowest grit was noticably worn, but the rest were fine. It'd be nice if I could get replacements for just the lowest one or two grits without having to buy a whole new set.
Yes. Micro-Surface sells individual pads for a couple of dollars each. Considering shipping, I don't know if it would be cost effective vs buying a full set of 3x4 pads and cutting them down. — DaveDoes anyone know if you can get individual grits of the MM anywhere? I recently did a batch of 110 pens, and started with a brand new set of MM for them. By the last pen, the lowest grit was noticably worn, but the rest were fine. It'd be nice if I could get replacements for just the lowest one or two grits without having to buy a whole new set.
Wow. Turns out it's not at all cost effective because of the shipping. $3 for a 3x4 pad and $13 for shipping. What a shame.Yes. Micro-Surface sells individual pads for a couple of dollars each. Considering shipping, I don't know if it would be cost effective vs buying a full set of 3x4 pads and cutting them down. — Dave
