Alumilite..............
rd_ab_penman
Red Deer, Alberta, Canada.
Clear Slow and ONLINE Label paper applied on Sierra series tubes use
to make up another batch of guitars.
Les
Les - about your process...Do you paint the tube white - allow to dry then adhere the labels with CA?
T
If you use "weatherproof" labels from OnlineLabels.com you'll never need to paint the tubes or use CA. They are self adhesive vinyl with no sealer needed. Just print, stick, and cast.
