A Semi-kitless Fountain Pen +104 Levers
See more from Rolandranch
Rolandranch
Tucson, AZ
I made a custom fountain pen with some Royal Jacaranda spectraply. I modified some of the parts of the RAW kit for the threads since I haven't gotten into threading yet. Making the section was a challenge and figuring out how to convert it to a #6 nib instead of a #5 nib took some creative drilling techniques, but I'm happy with how it turned out.
And then there's a bunch of ironwood lever action pens I recently made to fill some orders. I needed 105 for the orders, I started with 108, and ended up with 104 because a few broke along the way. So now I'm one short and have to go make another one 😅. I don't mind doing the "production pens" but the custom pens are definitely more fun to make.
Wow, that's a lot of revolvers!
I really like that fountain pen. Would you mind sharing how you modified/made the section?
Thanks! To be completely honest, I did a lot of little tweaks on the section until it all finally worked together and I'm not sure I can remember everything I did. I wouldn't do it the same way again because of how thin the wood ends up being. It's literally paper thin at the top. But basically, I trimmed down the brass section, cut it in half, and inserted it into the wood section I made. I had to strip the threading off the #6 housing and make it press fit into the brass section. When I thought it was done, the wood section didn't fit into the cap so I had to turn the wood section down even further. Then the cartridge wouldn't insert far enough to secure to the housing so I had to drill the brass a tad wider to make it fit.
I don't know if that helps at all or even makes sense. But it was kind of a nightmare and you could probably figure out a better way. 😆
Brilliant work, simply brilliant. I love it when the pen cap and main body form a "rod" and have this seamless look. In this pen the metal threads that form a "double" copper ring when closed, really enhance that look. Bravo once again.
Beautiful writing instrument.
The seciton on the fountain pen is awesome! But i'm still trying to figure out how you modified the cap to get the threaded portion 🤔
Thanks! I just trimmed down the brass cap to where I could fit it into the hole in the wood and then cut the end off. I left about 1/16" untrimmed on the screw end (this is the exposed trim ring).
I should have known this beauty was yours; bravo!
