Glueing blanks
Two-part 5 minute epoxy, unless I'm gluing multiple kits at the same time. Then I'll use 15 or 30 minute. I never use CA or polyurethane glue.
I routinely start working with an epoxied blank after only 15 or 20 minutes. Haven't had one fail yet. Knock on wood. (See what I did there?)
I assume you are using the stick-fast brand that you posted a picture of? I haven't tried that one yet.
Also, are you talking wood to wood, wood to metal, acrylic, etc? Also, are you doing this on a relatively simple 90 degree segment or something more complicated?
I would love to be able to start something 20 minutes after I set the epoxy.
Medium CA. If I feel speeding up the process I spray each end with accelerator and go for it. As for which to use CA or epoxy…. No rules… use whatever works best for you.
I'm talking brass tubes to wood or acrylic. I don't do segmented pens.
Wow, I need to learn to read better. All this time I thought this was in the segmenting forum.
For tube to blank adhesive I just use thick CA unless its a segmented pen or a wood that is prone to blowouts, then I use epoxy.
5 minute epoxy means you have 5 minutes of working time, after that the epoxy is setting up .
But cure time can as said by painfullyslow can be 12 or more hours .
1 hr epoxy the epoxy has 1 hour to soak or wick (working time ) into wood/plastics or bone/leather.
and its about 24 hour cure time if being used for bonding .
For epoxy finishes can be up to 5 to 7 days depending on how many coats are put on .
Some inlays I CA in depending on the inlay but then everything is getting soaked or covered with 1 hour west systems marine epoxy for the sealer/finish .
I don't use 5 minute epoxy. because I think one hour epoxy wicks into the wood farther for a better longer lasting bond .
