Three more 3mm Sketch Pencils
See more from mmayo
mmayo
Tehachapi, CA
I like to vary the tonality in my sets of pens and in this case pencils. Diagonal bocote, Peruvian rosewood and maple burl helped spread the spectrum. The last redwood burl completes this initial offering of this kind of pencil. CA finish as with all of my pens.
WoWser your CA is finish is Deep.
Nice.
I sand to 400 grit
Clean with alcohol
Let dry thoroughly
On the lathe running at 500 rpm's
Apply 4 coats of EasyBond thin 5 cps
Spray lightly with Stickfast aerosol
Apply EasyBond thin 50 cps (pen finish)
Repeat three more times
Reverse the lathe
Possibly give four more coats with lathe forward with spray.
This takes me 5-7 minutes
Let cure for 2hrs to overnight
Sand with 400 grit with lathe spinning and then laterally
Buff of the first two wheels of the Beale buffing system
Examine carefully and repeat buffing if needed
Best of luck with your CA efforts.
Once again your Finish is outstanding. I think your photography, and the long straight lines of the pencils provides a continuous plane to view your finish, and see it along the entire length. Really, really nice.
very nice work, which kit is that?
