Ten cheese slicers getting finish
See more from mmayo
mmayo
Tehachapi, CA
After a considerable delay in availability of cheese slicer mechanisms I can finally restore my inventory. My home brew of mineral oil and organic beeswax works well. Three hours of saturation helps to penetrate the wood. I use cherry, maple and walnut as the base wood around the inlays.
egnald
Columbus, Nebraska, USA
Very Cool. I like the shorter distance (2-inches) from the cut to the end of the board that the small cheese cutters give, however, I like the longer cut distance of the large kits. I haven't done it yet, but I've been thinking about trying to cut about a half inch or so from both sides of the cutter arm to see if I can make a modified board with the long kit but with a shorter distance.
Do you think I have a chance of success or would I just be wasting a kit and board?
Dave
mmayo
Tehachapi, CA
Dave
I would not know how to determine it. I admit to using the directions and directions almost exactly and I get perfect results. Mine is called a long arm mechanism. Best of luck.
egnald
Thanks. I think that is what mine is called too. They are pretty much the same as the ones that WoodCraft sells, but I get mine from CheeseSlicing LLC in Sheboygan, WI.
Bryguy
New Hampshire
Where are you getting your kits from? I've been looking for them for about three months and everyone was out of stock.
mmayo
Tehachapi, CA
I now have six of each for six categories of cheese slicer in my home inventory. The gallery has three of each category. Whew!
Back to shave sets, Saturns, bottle stoppers and seam rippers.
I must be wicked!
