Black palm slimline
Scry
Kansas City, MO
First time I've worked with palm before and I can very confidently say I will almost never ever touch this stuff again.
Started off using carbide tools and when that created too much chipping (and subsequent incredible amounts of splinters in my arms) I opted for to sand it all the way down.
I thought turning ebony or any of the black woods were annoying before, but this simply takes the cake. Pretty pen though... only took me 3 hours to finish...
NZ
Nice pen though.
Maybe not worth the pain?
Todd in PA
Port Matilda, PA
I stabilized a couple of palm blanks when I had a batch going… but still haven't used them. So I can't say yet whether stabilizing made it easier to work with.
qquake
Northern California
Great looking pen! I've turned black palm a few times, but don't remember having any problems with it. I used a radiused carbide cutter with a shearing cut.
Amanap
Plant City, Florida
I stabilize my own and have never had a problem. I am not sure if the difference is the way I am stabilizing or my palm is different. For the soaking I put in my pressure pot. Black palm comes from a species of palm tree in Asia , I am using Queen Palm.
Scry
Kansas City, MO
I noticed that using the detail cutter carbide gave me very little trouble, though it was still creating some chipping and by that point I was already getting close to the tubes so I didn't want to risk it and went back to the 80 grit abranets.
qquake
Northern California
The diamond shape cutter?
MRDucks2
Bristow, IN
We're you using Cactus Juice (or equivalent) or something else to stabilize, William? I have a process in which I utilize CJ and a pressure pot but had not tried it with palm.
Amanap
Plant City, Florida
I also use CJ. I have a plastic container that fits inside both my vacuum chamber and my pressure pot so I vacuum like normal and then transfer to PP and put under pressure for 2 times the vacuum time. Just not sure if it my stabilizing technique or the type of palm I use but never have any issues.
howsitwork
Thirsk
I must try that techniques as even with a shearing cut with razor sharp HSS if you took your eye off it even for a second it splintered!
I stabilised it first with stickfast and should probably have soaked after vacuum for a bit longer . Didn't pressure treat afterwards though
