KMCloonan
Is there some special technique for seating a MT2 keyless drill chuck into the tailstock, or tightening the bit in the chuck? Here's why I ask.
I have been using a keyed drill chuck for years, and I decided I would treat myself to a keyless chuck, for obvious reasons. The last couple of blanks I have drilled using the keyless chuck have been amazingly bad. The holes end up way too large. I keep looking at the chuck - I don't see any obvious wobble. I don't have a runout gage to actually be able to measure it, and with the bit remaining stationary, it's difficult to eyeball if it is cocked.
Today I needed to drill a large bore hold for an Olympian Elite 2 - the body blank uses a 31/64" bit. I decided to drill an 8mm pilot hole, just to guide the larger bit. I had no trouble drilling the smaller hole. You can see it came out centered and clean.
Then I chucked up the 31/64" bit (a PSI bit I have used for many pens, still sharp), and started drilling. About halfway, I had to stop. It was obvious that the hole was too large.
I measured the hole, and the bit - the hole was about .100" larger than the OD of the bit.
Here is the Keyless Drill Chuck I just got a couple weeks ago from PSI
I need to get this pen made, as I am about 2 weeks behind schedule, so I reverted back to my keyed chuck - I inserted it into the tailstock with a slight twist (I did the same with the Keyless Chuck) - I cut a new blank, and drilled it using the same 31/64" bit, and the hole turned out normal.
My lathe is new - I got it in October. The MT2 bore in the tailstock looks ok. It seems like my problem is coming from the keyless chuck, Is there a trick to seating it? is there a trick to inserting and tightening down on the bit?
Any guidance or suggestions would be appreciated.
Thanks,
Kevin
Thanks,
Kevin
