Halloween prototype
See more from Fred Bruche
Fred Bruche
Philadelphia 19146
Seems I have had a small out-of-round problem lately, it's kinda subtle, can you spot it?
On top of that, it glows under UV light!!!
It worked like a charm, thanks a bunch @rherrell !!
Very nice, very cool! Didn't know locust would fluoresce under UV...that is very interesting...
Any chance you could show the nib of the pen?
Another fluorescence I discovered going around the shop with a UV lamp, the red in flamed box elder pieces has a nice orange glow.
The section in these pictures was scavenged from another pen, a dedicated section made the same blank as the center band is in the making, I'll post a picture once it's finished.
I like the slight unbalanced look. It seems even more custom made by hand. Also like that the center band changes color under UV, too. Do the offsets/flats/whatchamacallits line up when it's closed?
Thanks Todd! The picture shows what I was aiming for (this was a test piece, not a pen), a twist running along the length with the "crest" on one end would match with a flat on the other end. In the pen the junction between the cap and body would be in the middle where the "crest" is at its lowest. And by using a triple start the body and cap would always align that way. In retrospect, using honey locust was not an ideal choice for the blank, the straight grain and uneven texture made the cuts too coarse. I'll probably use maple for the next try.
