Stephanie
This is a challenge. Pretty sure I had the bushings in the right order. Pretty sure....I even turned one at a time. The two pieces looked amazing. Then I realized...
1). Pay attention to the grain, before you put the bushings on and turn it. This complicated little bugger has no mercy.
2). Check to make sure the pen blanks are the right length before turning. Not sure how, thought I was pretty careful when I drilled/sanded to the brass, but one was shorter then it was supposed to be and so the ink refill turning thingy doesn't work properly.
3) Glad Take #1 is always the silver finish. Not a fan. Tomorrow we go gold. Take #2.
4). If the bearings had been in the right place, I did do a pretty good job getting the ends matched up with the bearings and the sloping size difference of each end.
Hopefully the batteries for my calipers arrive early. I need them. Apparently my sense of size is a bit off, as I obviously did not get the bushings in the correct order.
