Lignum Vitae / African Blackwood
moe1970
Inverness, FL
What are the recommended finishings for Lignum Vitae and African Blackwood? I am turning my first ones soon and have read that they are very oily. Is it better to just use that oil as a finish or will CA hold? Thanks in advance.
magpens
Canada
In my experience CA can be applied to Lignum Vitae.
How long it lasts I do not know. . Lignum Vitae used for pens can be difficult .... The wood can crack several years after finishing.
I have had this happen more than once. . The wood seems dry ... make a pen and finish with CA ... several years later stresses seem to build up ... CRACK !
The crack seems to originate in the wood .... not the CA finish. . The thickness of the wood on the brass tube is under 0.10". . Long Clicker pen kits.
Strangely, unused pieces of Lignum Vitae from the same batch have not cracked. . But of course, they're not glued to brass so are free to move at will.
eharri446
Marietta, GA
I know that Stick Fast has a CA glue which has some flex to it. Would that prevent woods like snakewood, African Blackwood, and Lignum Vitae from crack once they are glued to a tube. Or would epoxy be a better glue for those woods?
Pierre---
France
CA will wear with use, as any surface finish. The beauty of very hard woods is they are very dense. So I would just polish it, up to MM 4000 or more. Maybe oil it w with BLO (not a surface finish, but impregnating will theoretically fill wood under the surface , even if I am not sure it could add something to such hard woods like Vitae and African Black wood.
So in doubt, just make a careful polish and that's it.
PatrickR
Rural America
I can't comment on Lignum, I have some but have not turned it into a pen. I have made several using African Blackwood and finished them with CA. It has been fine, no cracking or adhesion problems. AB is not as oily/resinous as Lignum but just as hard and dense.
PatrickR
Rural America
No, in my experience. I have not had cracking issues with AB but have with SW and Pink Ivory. All used epoxy and CA. I had a set of SW ready to assemble that sat on my bench (un heated) for two years without cracking. It cracked very quickly after assembly. I think it was the radial pressure. I am trying some things now to keep them from cracking.
Bryguy
New Hampshire
I don't finish my Africam blackwood pens with anything. Sand to 1500 grit and polish with Renaissance wax.
qquake
Northern California
I used Watco Danish oil on this one.
GuyOwen
Minneapolis Minnesota
Bees Wax in my experience Lignum vintae finishes really well with bees wax i have only turned ebony and not black wood
