Polishing Compounds
BryanMurphy
Michigan, US
I was wondering what you all use to polish pens. Specifically things like Ebonite, diamondcast or resins.
For wood I am using Tripoli, White Diamond, and Carnuba Wax.
carlmorrell
Cary, NC
Forever, I used micro-mesh then Maguires Scratch-X. Regardless of CA finish over wood, plastics, or ebonite. (I have made quite a bit of ebonite). Sometimes, when I make a mistake, usually not sanding parallel to the body, I get all done and see scratches, more visible on dark surfaces. Last summer, I decided to get the 3-wheel buffing system from Penn-state, and have to admit it, but it seems to make everything pop a little more. So I think you are already on the right track!
Two observations I can not stress enough. Wet sanding will hide scratches. Make sure you dry off to see if there are any scratches before progressing finer. Second, I ALWAYS have on extra magnification. I love my Donegan glass visors. My opinion there is, if I can get the scratches out with magnification, they will not be seen without the magnifiers.
rixstix
Canistota, SD USA
From my picture framing days, polishing acrylic was always done using Novus 3-2-1 products; so that is what I use by old habit on acrylic and other resins. Never looked for anything better or easier.
Fuquay Varina, NC
I did a few variations of the same thing for 10+ years... Then a friend of mine gave me a set of "Magic Juice" polishing liquids to try and it was a game changer.
In the past I'd wet sand with 800,1200,2000 work by way through the 6 or so grits of 3M polishing paper (You know it as Zona possibly) then use two different 3M polishing compounds. It worked but it was certainly a lot to go through.
After trying Magic Juice from Stadium blanks I'm hooked. I still do my 800,1200,2000 but then I just go through the 6 grits of the liquid abrasive using a microfiber towel with my blank on the lathe and it looks as good or better as anything I've taken to a buffer. Once I found out what he's rebottling it made a lot more sense. It's basically one of the best liquid abrasive products on the planet that runs $180 per "grit" in the full bottle form. Thankfully a little goes a long way and him rebottling it makes it a lot more approachable than having to spend $1k+ on a good liquid abrasive system.
henry1164
Webster, NY
This only works when you have the blank turned/tooled to a smooth finish with no tool marks (i.e. use skew as final tool), no depressions, scratches, etc. and you can start sanding at 400 grit. With wood I sand to 1000 grit, clean with DNA (and let fully dry) followed by CA - most times I use thin only and about 8-9 coats. After CA has fully cured I sand from 600 grit to about 1500 grit. Then I use Dr. Kirk's Red/White/Blue at a high speed - about 2500. I know when it's working as I get some heat through the paper towel. With acrylic I sand to 2000 grit then use Dr. Kirk's as above. After Dr. Kirk's and keeping the speed the same I apply Meguair's PlastX also looking for the heat. Not having to use micro-mesh is a time saver, eliminates the need for water and gives an excellent result.
peytonstreet
Santa Cruz, CA
Here here on the Magic Juice! I go thru the Abranet mesh sanding sheets up to 1,000 grit, then switch and polish with the 6 grades of Magic Juice. I don't even have to buff as the last grade of Magic Juice does better than Caswell fine and extra-fine compounds.
