I didn't realize the Bolt Action Tec-Pen bushings are the same size. Thanks for the heads up!
I seen them and I plan on ordering some. I looked at the instruction sand it appears there is plenty of "meat" to allow segmenting.
I was hoping for a little more. I think it can still be segmented though.The "meat" is not a heckuva lot .... about 1.4 mm.
I get this from the OD of the bushing and the brass tube size .... 0.5 x ( 0.425" - 8 mm ) = 0.5 x ( 0.425 - 0.315 ) = 0.055" = 1.4 mm
That bargain price must be for math-challenged pen turners. :-(
Sometimes you get a super high quality drill bit tooWhich ain't you nor me !! ... Right ?!!! . .
That happens quite a lot, actually ..... I always check !
But don't forget that you get the bushings with the starter set ..... that makes a huge difference !!!
The bushings are 5.95, so if you include them in the calculation, you are saving their cost ..... which is not as much as they claim you save !!!!!
But it does make you wonder what advanced degree in Marketing "they" have in order to come up with "their" published deal !!
