Sawdustsmiles
Has anyone had problems with 7mm slimline twist pens retracting during writing?  Would crimping the transmission slightly work? Any transmissions out there that dont slip and retract.
Yes all the time. But it only seems to happen when I loosen the transmission. Sometimes when the come are very stiff with grease so I loosen them and that's when the problem starts.Has anyone had problems with 7mm slimline twist pens retracting during writing? Would crimping the transmission slightly work? Any transmissions out there that dont slip and retract.
I totally agree. I have not crimped anything yet. I have probably made about three hundred or so of them. Hope they don't start coming back with this problem. My wife's does it. and I have heard a new customer isI would NOT crimp anything.
I believe that the twist transmissions used in all pen kits, including the 7 mm slimlines, are designed so as to NOT retract without deliberate effort.
If the do retract by themselves, I would say there is something wrong and you should go back to the kit vendor with a polite complaint.
