10 Minutes To Better Pen Making - Painting Acrylic Before Turning
mg_dreyer
Aurora, Ill, USA.
Albeit we probably all know by know that acrylic pen blanks need to be painted before turning - I did this video for some of team still new to pen making. In this video I go over how I paint the blanks, the reason I paint the hole and not the tube, shapes, and dramatic effect I can get mixing colors. Just wanted to step back and give my thoughts on acrylic blank prep.
10 Minutes To Better Pen Making - Painting Acrylic Blanks
Let me know what you think.
That's really interesting! I tend to have trouble with the paint being removed when I insert the tube. How do you prevent that? I have heard you should drill the hole a little larger but have not had luck with that.
I am sure Mark will answer.
However, I spray krylon/Rustoleum inside the barrel and outside of tubes. I allow the paint to dry for a full 24 hours. I use epoxy (it acts as a lubricant to some degree). I have probably had that issue 1 of 100 times - and believe me, I have no special skills. I do then allow the epoxy to fully CURE per the instructions. Happy turning!
Hi Mark,
Very good video, but I would like to have seen how you paint two different colors in the blank. Painting the blank one color (which I do) is pretty straightforward; painting two colors, not so much.
Tony as you know I always look forward to the different ways people do things - and appreciate people joining in. The goal of my videos is to think about all the aspects of pen making and sharing is great.
I never used spray but I will look into it.
PS and if you keep this as a secret, I actually don't paint the holes anymore - my wife does all the prep work. She paints the holes and does all my gluing.
Hi Mark,
Sorry I did not explain this well. I will use a Qtip and from one end (generally the middles) paint the white and go about half way up the blank (maybe a little farther). Let that dry over night. Then from the other side I use black paint and go the white and over lap. I try not to be perfect because I don't want a line - more a vignette. Hope this help.
Here is a better shot of the pen from the video (sorry about the image quality - screen snapshot). Black on the outside end white in the middle. The blank is a generic yellow blank.
Here is a shot from the video of the original blank ...
Great video and heavens what a difference he depending upon tube colouring. Never considered using tube colour to add or determine the overall look before.
Many thanks 🙏
That leads me to believe that the paint is not sticking to the tube properly. Are you sanding your tubes before painting?? I run a small file up the blank before inserting the tube. The next thing to do is paint the inside of the blank.
Lin
I really don't have that issue on the larger diameter kits (10mm / 10.5 mm / 12.5 mm). On 7mm I always drill at 9/32" which when painted leaves a hair room to glue. I use 5 minute epoxy to fill the gap. Never had an issue. I have another video on gluing out there.
Many thanks 🙏
JT The Clockman has a great example from a BASH or Extravaganza entry a year or two ago. If i recall correctly, it was light blue paint for a copper-colored blank--but that may be faulty memory on my part. Hopefully, he will reply with an updated link to that pen--it was beautiful.
earl
