Is there a trick for this. Seriously, I absolutely hate this chore. The adhesive never ever comes off with the sanding disc and the adhesive sticks tight go the metal disc. So, I peel off as much as I can. I have tried heating it a bit With a heat gun, doesn't seem to help much. I end up using acetone with a scotch brite pad. Takes forever. It's not like I'm using cheap low quality disc, the ones I have are from Kingspor. So any tricks for this?
