Rams Horn Advice Please
Alan Morrison
N Ireland
A friend makes shepherd's crooks and gave me his offcuts after fashioning the crook.
I cut a couple of the 'meatier' parts, boiled them for 20 minutes and straightened them on a vice.
I turned one, sanded to 600g and them MM and buffed.
Advice please on a good finish. ( not a CA fan )
Alan
Nice! I like to seal things that were living! So I would put 1-2 coats of thin ca and then sand and polish -you dont have a ca build up and it finishes nicely.
Thanks for the onfo, Keith.
Woud sanding sealer do the same job as the CA?
What grit do you sand up to?
Alan
polyurethane? Separately, I wonder what they would look like as worthless wood/material fragments embedded in an opaque colored resin (like dark blue or black).
Hello Tony. I have a few pieces and will be able to experiment with different finishes. I have used Tripoli and white Diamond on one and the next one will be Melamine Lacquer. Polyurethane will get a go as well. Thanks for the suggestion.
I'm sure that they would look good in resin as well but I will pass as it is not my favourite medium.
Alan
Alan
you are welcome
