First resin blank
See more from Alchemist
Alchemist
Central Valley, California
It's been about two weeks since a made something since I caught the Covid-19. I was fooling around with resin, making my own pen blanks. Turned this today. I'm still learning to make a blank centered. This one I should've taken more time with that.
howsitwork
Thirsk
looks good , well done. Very nice result and glad you've recovered.
I'm trying hybrid wood and resin blanks with varying degrees of success so far.
Alchemist
Hybrid blanks will be my next step. I don't plan on going to deep into resin casts till the future. Do you use a pressure pot? I'm curious if I really need one.
JohnU
Ottawa, Illinois
Nice blank! You did good! If your going to make hybrids I would suggest using alumilite resin, since it adheres well to wood and doesn't shrink and pull away from objects like PR resin. Alumilite resin works best with a pressure tank. Without it you will have a blank full of cured bubbles.
Keep up the good work and hope your feeling better!
howsitwork
Thirsk
Well so far I have used Aluminite with a pressure pot and some success. I am currently trying a different resin which I have used with and without pressure and it seems successful.
Having said that I have just had to extract a layer and repour as I got the mix wrong and it was , after 3 days , still mainly liquid ! Most messy and irritating as I was trying to be so careful. added a bit more hardner to the new pour to cure any semi set layer ( I hope 🤞)
Hybrid blanks, both stabilised and unstabilized are most satisfying to make . Pine cones look wonderful but as yet I've not made anything with the ones I've cut to pen blanks. These use A LOT of resin to make them .
Alchemist
These blanks were Alumilite. No pressure pot used. I used pink silicone to make copies of some other blanks I had. I lucked out with no bubbles in my blanks. I find that mixing and pouring carefully helps with this. I suppose I will get a pressure pot in the future because I do know that alumilite and moisture do not get along.
walshjp17
Weddington, NC
Which Alumilite resin did you use - Clear, Clear Slow, Amazing Clear Cast? "Alumilite" is actually a brand name not the name of a specific resin.
vgonzalez0109
Indiana
I converted a 5 gallon paint kit into a pressure pot. Cost me way less than purchasing an actual pressure pot and it works like a champ. Only made a few resin cat keychains for protection for my daughters but looking forward to making pen blanks. Cold is not my friend here though
Alchemist
Since this pen was made I have bought a woodcraft pressure pot. It was well worth the money. I also feel safe with it.
