Dieseldoc
Looking for a. BI-METAL 3/16 10tpi 95inch blade.
Has to be BI-METAL
thanks
cheers
Charlie
Has to be BI-METAL
thanks
cheers
Charlie
JT:Timberwolf blades are good blades and I use a few. My favorite blades are Lennox. https://www.lenoxtools.com/pages/lenox-lenox-bi-metal-band-saw-blades.aspx Guess you are planning on cutting metals.
Bill:Thanks I have been in contact with them, smallest width is 1/4. in Bi-metal.Give Iturra Designs a call at (904) 642-2802. Ask for their catalog while you're at it. They are a great source for all things bandsaw. Unless things have changed recently, they do not have a web presence.
Bill
My goodness there is a ton of materials. I could not understand why you want to use something that is so hard to cut. It will take its toll on your turning tools also. But who am I??Testing with scroll saw and. Bi-metal blades failed due to the lack of finding a blade that would be used to cut small radius. Found a diamond blade but it was to thick leaving more of a void in the blank for the infills to fill.
Bottom line. G-10 and can be used when you cut large radius with the smallest. Bi-Metal band saw blade which is 1/4 inch.
G-10 material is so hard that it eats up any blade that is not diamond or Bi-metal, even with Bi-metal , blade life is short. so going to find other material for thin infills.
