WriteON
Rocker's blue apron. Is it me. Am I that bad. I need a degree to get the apron on. I need a Utube vid to understand how it fits. I feel like I'm playing Cats Cradle.
Yes it's denim. Who designed it should have their sewing machine confiscated.I'm assuming you're talking about their denim apron? If so, that's why I had my wife make mine, perfect fit and you don't need a degree to put it on. Just make sure your arms can reach around so you can tie it behind your back. Simple loop slips over the neck and it takes me maybe 10 seconds to get it on. And it's comfortable and keeps the chips off me.
I do have it figured out. Trash can, rags, dust cover for something.That's one of the reasons why I had my wife make mine. It's very heavy denim but not in weight (if that makes an sense). After she got the pattern cut out if was custom fit to me and I put the pockets where I wanted them. I'm pretty lucky that my wife has the talents to do stuff like this, cause I sure don't. Sorry it didn't work out for you and hopefully you can figure something out.
I might cut the straps use safety pins.Pretty expensive rags or dust covers. If you can find someone that sews you can probably get it less than that and it will fit...and not give you fits. Good luck.
