No pun intended but does fit
OK here is my latest 2 pens on Sierra Vista kits. There has been many pen blanks shown using diamonds and segmenting and I will eventually get there too. But here is one of my diamond version pen blanks. I need to use an epoxy resin which I found best to adhere to anything when cast so did not want to take any chances. I needed to color the blank too and thus my attempt at this. I used a blue metallic mica powder on one and a matt black on the other. Again sticking with my theme of using materials readily available to all but rarely used or at least I have not seen them used much. The resin we all know. The diamonds are actual mother of pearl inlay diamonds used on both pool tables and pool cues. They can be had at pool cue supply vendors. Again with this material it is hard for me at least to get a good replica photo showing the glittering and movement in the pearl inlays. It shows as you turn the pen in the light. Also once again any comments or questions are always welcomed. I doubled up on one of the photos in hopes of seeing the change in light. Thanks for looking.
One other thing, I shown these to a friend and now he wants a green so I am going to have to play with coloring the blank again. But out of curiosity as you may notice I reversed the pattern on both pens with the fancy diamond and the solid diamond, which do you prefer??
