Pau Ferro and Trim Rings
See more from mark james
mark james
IAP Collection, Curator
Strongsville, Ohio
This was a special order for an individual in Louisiana. It was received, so I thought I can share. The request was for a Rollerball with trim rings, the base blank was my choice.
Pau Ferro blank, walnut and maple trim rings. Glu Boost finish.
Great work Mark. I love the trim rings...even better with veneer in the joints. If you look at pinterest.com with segmented wood/woodworking/pen blanks, etc. some of Mark's beautiful pens will pop up on the pages. Also some of my segmented blanks that I constructed many years ago.
Did someone say "the work of a pro" ?
Yeah !!! . I'd agree with that !!!!
Very lovely, Mark !!!!
@mark james
Mark, is there a tutorial on how to make those trim rings with 24 alternating colored wood segments ? .
I do have a Byrnes saw like yours but I don't know if that's what you used in this part of the process.
@mark james
Hi Mal, I have not written a library article on the trim rings. I do these on "Frankie"... my Atlas Clausing Metal Lathe skelton (No motor, no pulleys, no brain, out of the wizard of Oz!). It has a heavy duty indexing plate and a back mounted router).
I have shown these before (don't want to bore folks), but here are a few shots:
BTW: I have only been able to do 12 rings max, as the remaining material in the middle tends to "explode" with higher numbers of slots. BUT, If you make multi-layered inlays you can easily get 24, 36 colors, just in a different sequence.
@mark james
Thanks very much for this additional info, Mark. . If you have presented it before, I apologize for causing you to repeat. . I don't remember, and that is certainly a reflection on no one but me !! :(:):rolleyes:🥵
@mark james
Thanks very much for this additional info, Mark. . If you have presented it before, I apologize for causing you to repeat. . I don't remember, but that could be mostly a reflection on me !! :(:):rolleyes:🥵
I have displayed all the pertinent info in bits and pieces (at least how I do these), but have not taken the time to collate a clear thread. That would be a good day's project as the trim rings are very feasibly for others to make, but I have suspected look too intimidating for folks to try. Truly, they are well within the realm of metal lathe users who can add a palm router.
I'll work on a library article and send you the drafts to give me some feedback. Why not be productive while we hunker down!
@mark james
"I have displayed all the pertinent info in bits and pieces (at least how I do these), but have not taken the time to collate a clear thread. That would be a good day's project as the trim rings are very feasibly for others to make, but I have suspected look too intimidating for folks to try. Truly, they are well within the realm of metal lathe users who can add a palm router.
I'll work on a library article and send you the drafts to give me some feedback. Why not be productive while we hunker down! "
Sounds good . Will look forward to that . More in a PM.
