Polishing paper
qquake
Northern California
Anybody tried this? Any good?
duncsuss
Wilmington, MA
I've been meaning to buy some of this from Amazon for a while - it looks identical to the PSI offering, apart from the pieces are a different shape, and it's literally half the price per square inch. ($0.15 per sq inch versus $0.307 per sq inch).
I believe 3M make one grade that is even finer grit, but I've only seen it in the adhesive-backed version.
FGarbrecht
NY
Yeah, agree with John, this is just repackaged 3M lapping film. It's works well for lapping and sharpening (this is what I use for sharpening my chisels and plane blades) but can be found cheaper. The grit is embedded in a fairly flexible but firm plastic backing and is probably fine for final sanding and polishing.
duncsuss
Wilmington, MA
Just for the hell of it In the interests of scientific inquiry, I ordered some from an eBay vendor who sells it even cheaper than Amazon. If you'd like to try it yourself ...
sells it even cheaper in half sheets if just experimenting
https://www.ebay.com/itm/3M-Tri-M-I...373650?hash=item2cd33a4a12:g:UVYAAOSwOFZeD9uE
TonyL
Georgia
Hi Duncan. What do you think of it?
duncsuss
Wilmington, MA
Thanks, John - I saw the half-sheets and decided to go for the lower-per-square-inch price of the full sheets; I would be very surprised if a 3M product disappointed me, and I know that I can use the 1 micron grade for smoothing fountain pen nibs if nothing else.
Tony - I had barely finished the PayPal transfer when I typed that! When the goods arrive and I've used them a little I'll post a follow up.
TonyL
Georgia
Thank you.
Edward Cypher
Denver, Colorado
I use the zona polishing paper and it works just fine. it is similar to micro mesh but has been used in the jewelry business for a long time. Goes to a little finer than the top grit of micro mesh.
duncsuss
Wilmington, MA
My pack of 6 grades arrived yesterday; it has a label stating the grits are 400 / 600 / 1,200 / 4,000 / 6,000 / 8,000 but doesn't say which measuring system they use. (Micromesh finest grit claims to be 12,000 - but could be on a totally different scale.)
I might get to take some for a test drive this weekend.
qquake
Northern California
I got mine today, but the colors don't seem to match up. I can't tell which is which, at least not the finer grades.
qquake
Northern California
I did a quick test with the Tri-M-Ite. I sanded the body with 150 grit dry, then used all six grades of the polishing paper wet. It actually worked better than I expected. I realize I didn't get some of the bad scratches out, I was in a hurry. I just wanted to see if it has promise. I'll try again with Micro-Mesh later to compare.
TonyL
Georgia
Much better. Watch the ends (near the bushings). I find that I have to pay particular attention to the ends because of their curve away from the sand paper. Many times the body of the pen appears scratch-free, but when focus my loupe on the ends, I can kick myself for not doing a better sanding job.
qquake
Northern California
Looks like I need new Micro Mesh. This is after all 9 grades.
qquake
Northern California
So I decided to try all 6 grades of the polishing paper. Worked pretty good. I just realized there are only five photos. I obviously missed one.
qquake
Northern California
I was more careful with the ends this time. This is after ScratchX.
qquake
Northern California
I tried again with some new Micro Mesh. The polishing paper obviously did a better job at removing the heavy scratches.
qquake
Northern California
And just out of curiosity, I tried the ScratchX. It made it a little better, but didn't take out the heavy scratches. I didn't think it would, but it was worth a shot.
qquake
Northern California
Me too. I had replaced Micro Mesh with Dr. Kirk's a while back, which gave me similar results. But a lot of times I would get micro scratches, and the OCD side of me is trying to eliminate them. My process was wet sand through 500; Dr. Kirk's; and PlastX. Then I added swirl remover, and then ScratchX. That's a lot of steps, but that may be what it takes.
TonyL
Georgia
If washable, I would use warm water an a drop of dishwater with a soft toothbrush (that is what i do with MM)
duncsuss
Wilmington, MA
How would you guys clean this? Warm water and a brush?
I'm planning to cut the sheet into strips about 1" x 2.75" (about 32 pieces from an 8.5 x 11 sheet) and throw them away after using.
My friend and teacher says "don't use sandpaper like somebody else is buying it -- use it like toilet paper, just once then get rid of it."
qquake
Northern California
I don't know what happened. This is a blank from Classic Nib. Everything was looking good, until I got to the pink. These aren't scratches, it's something on the surface. I used water, but maybe not enough? Anybody ever seen this before?
duncsuss
Wilmington, MA
My best guess is it overheated and the fine powder that the paper was taking off the blank melted and fused back onto it. Slower and wetter would be my recommendation.
I got a similar thing once when I was buffing a Cebloplast pen barrel, fortunately there was enough wall thickness that I could get rid of the streaks by going all the way back to 120 grit and doing the whole process over.
TonyL
Georgia
I have done the same. When i experience this, i kick it back a few grits (the bck to the finer grits), slow the rpms to 600 to 800 (my usual settings) and make sure i am letting the sp do the work. excellent progress.
qquake
Northern California
I ran through all six grades again, this time making sure it was plenty wet. What a difference! I really do think this is better than Micro Mesh.
qquake
Northern California
I polished it with Meguiar's 105, Swirl Remover, ScratchX, PlastX, and 205. I don't think I can see a difference. I think I agree with TonyL, 105 and 205 would have been enough.
qquake
Northern California
I tried the paper on a different blank. Very happy with the results.
duncsuss
Wilmington, MA
I used this for the first time today on a piece of vintage celluloid; I like it a lot.
First I sanded with 320 grit using my regular method -- Vince's WoodNwonders blue sanding disks on a hard backing mandrel, with lots of water from a misting squirt bottle. I find it the easiest way to get rid of any bumps in the barrel.
Then I used each of the 6 "papers" - I cut a strip off each and quartered it, so I had a piece about 7/8" x 2" to work with. In between each one I stopped the lathe and sanded up and down the length of the barrel, being very careful to get rid of any circular scratches before moving on to the next grade. I didn't use a backing block with these, just finger pressure and again plenty of water.
Normally I'd go through Micromesh then use Plast-X (or buff), I'm not sure I have to do either to this pen.
qquake
Northern California
I'm getting really good results with the Tri-M-Ite followed by Meguiar's 105 and 205.
TonyL
Georgia
So far, this has been among the best that I have seen - especially with a dark/unforgiving blank.
I did see fine radial scratches on one of your earlier posts. If you are not using a loupe, you may gain much from getting one (10x is plenty).
qquake
Northern California
I do have a loupe, but don't use it much. Most of the time when fine scratches show up in the photos, I can't see them with my naked eyes, so it's all good.
