Popping out cabachon
EricRN
How do folks pop out the cabachon on the jr gent IIs? I tried popping it out with a pen press and pen disassembly tool. No luck. Tried popping it out with a push bar and a hammer with the finial in a vise. No luck. Tried drilling out the center thinking it might relieve some pressure (like removing rivets). Still in there. I'm at a loss.
Fred Bruche
Philadelphia 19146
What has most consistently worked for me is drilling with a bit about the size of the cabochon tenon from the inside of the cap (held in a clamp).
hokie
Falls Church, Virginia
I drilled mine out and didn't have too much of a problem. As long as the bit is slightly larger than the diameter of the finial tenon, it should just pop out.
EricRN
Seems like maybe I didn't use a big enough but. I used just smaller than the tenon. I'll try a larger bit.
keithbyrd
Mount Wolf, PA
Drill a hole in a small block of wood just a hair larger that the clip end cap cabochon (finial). Using a drill press and a steel rod, place the cap over the hole with the final down, align it under the steel rod and push out with the drill press.
EricRN
Thanks. Issue was I was using too small a drill bit. Used a bigger one and it popped out. I like the idea of drilling a hole in a block of wood to hold it. Better than putting it in a vice. Less chance of messing up the finish or bending it.
Mr Vic
Falcon, CO
I use a block oh UHMW plastic. Doesn't compress like wood will and doesn't compress or crack.
magpens
Canada
@EricRN
So, please tell me ....
what size drill bit finally worked ? . I may want to do this in future.
Also, did you drill right through the cabachon ?
