crunch
The blank is African Blackwood. I cut it to length, 200 deg in the toaster oven, weighed until no change. 1 week to re acclimate to the shop 220-1000 grit radial and lineal sanding. Mylands sanding sealer at 1000, 2 coats, re sanded 3 times. Sanding is just below bushing diameter to accommodate the CA finish. 5 coats Stick Fast thin, 10 min between. 15 coats SF medium. Same wait time. The CA is coating the bushings so I scraped it off right up to the edge of the blank, lathe running. I get a de lamination...? at the bushings, not the main body. This is not my 1st rodeo. I've made 100's of wood pens but  keep getting this result. Not on every one but about 10%. On different woods also, some work, some don't
I'm at a loss. I know there are a ton of threads here to address the finish process, I just can't see what I may be doing wrong. Is 1000 grit too smooth to adhere to? Heat buildup from "parting" the excess CA off the bushings..... I really don't know what I may be doing wrong. The blank is clean, so are the bushings.
So I'm going to scrape all the CA off and resand/refinish, I tried to just scrape down to the wood at the bushings....yeah right.
Any thoughts are welcome.
EDIT: I should also say that after barrel trimming, either mechanical or by sanding disc, I use a Q-tip and thin CA to seal the ends of my wood pen blanks, Just an added precaution to water infiltration during the wet sanding process
